Question about Philips GoGear SA178 MP3 Player
Help Help Help
When i press play button it displays philips then go gear then format player connect player to pc when i connect it doesnt work
  • 476 Answers
Install and run the firmware upgrade software from the product CD.
Select repair/restore option and follow on-screen prompts.
Posted on Feb 20, 2008
How do I operate my Philips go-gear 8GB mp4 player. Serial # RK1H1051038306, model # 06095819004. I can't make out the users manual. What I am tying to do is, transfer my class lectures, recorded in mp3...
I have a Philips go-gear 4GB player. There is no charger included. To charge the player, use any firewire/USB cable and connect the device to a PC or laptop. While the device is charging, the battery icon is blinking. When it is fully charged, the battery icon will stay static.
To copy to the device, open Windows explorer. Look for the Philips Go-gear folder icon. Open the Philips folder and Copy you music files inside the device's my music folder. If the file is video, copy the file in the my video folder.
Once the device is fully charged, disconnect the device by right-clicking on the Safely Remove Hardware icon on lower right portion of your PC screen. Select Safely remove hardware then Choose the philips go-gear device to eject.
Power on the device then use the navigation keys to select the files you like to play. Click ok or the play button.
Jan 21, 2011 | Computers & Internet
My go gear mp3 player is connected and it said to please format mp3 player with pc and how do i do that
CONNECT YOUR GO GEAR WITH PC THEN ON THE DESK TOP PRESS WINDOS KEY ALONG WITH KEY "E", IT WOULD SHOW U MY COMPUTER AND THEN U NEED TO OPEN REMOVABLE DRIVE THEN U CAN FORMAT YOUR GO GEAR
Jun 25, 2010 | Philips GoGear SA3020/37 MP3 Player
My creative zen neeon hangs on creative logo what i can do?even it doesnt detects,then how can i format or reinstall the firmware?....plz help me....
try reseting it there should be a small pinhole on the back press and hold that for about 10 seconds if this wont work try putting it into recovery mode
  • Detach your player from the PC if it is connected, and turn off the player.
  • If the player stops responding, you can reset the player. To reset the player, gently insert a thin object into the Reset hole located below the power switch.
  • Press and hold the Play/Pause button while powering on your player.
  • When the player displays the Creative logo, release the Play button.
  • It will display the following options:
    Clean Up Scans the player and removes invalid links from its music library.
    Does not affect music files themselves.
    Format (All) Caution! Erases all content!
    Save a copy of your player's content before formatting.
    Reload OS/ Firmware Caution! Erases your player's firmware.
    DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
    Reboot Reboots the device.
    Sep 25, 2009 | Creative Labs Zen Neeon MP3 Player
    I am not able to play a dvd on the player it is displaying a X an
    This is not guaranteed to work but there are two process's that may work for your Philips dvd player. Below are two region hacks try them and let me know if they help.
    Process 1
    OPEN TRAY, PRESS 'STOP' BUTTON, THEN PRESS 7,3,4,4,6,6. ENTER '0' FOR REGION FREE, AND PRESS OK BUTTON
    Process 2
  • Turn your DVD player
  • On
  • The display will show you no disc
  • Press Play and then press 1, 5, 9 on the DVD Remote
  • On DVD display will appear ------ -----
  • Key in 101 040 000 140 on the Remote when you press the last digit you will see a little point
  • Press Play
  • The player will be turned off
  • Your DVD is ready
  • Hope one of these work for you, Thank you for choosing Fixya! Feel free to leave a positive rating if this solution helps you.
    Mar 21, 2009 | Philips Televison & Video
    Message showing - player problem connect pc and fformat player
    i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
    Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
    Files not playing on go gear
    Triple Reset for Philips’ GoGear:
    Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
    After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
    -Tha Mp3 Doctor
    Dec 27, 2008 | Philips GoGear SA3125/37 MP3 Player
    Snoy NW-E105
    I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
    The solution:
    1. Unhook your device from the pc by pulling out the USB cable.
    2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
    - This will show "Display"
    3. Click the " |<< " button 3 times (the button to rewind track).
    - This will show "Format"
    4. Click the Play/Stop button 1 time.
    - This will show "Format: N"
    5. Click the " |<< " button again 1 time.
    - This will show "Format: Y>
    6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
    Now your device is formatted and will play the files you add to it.
    Oct 07, 2008 | Sony Network Walkman NW-E105
    FORMAT PLAYER
    Use the Philips Device Manager to perform a Repair
    Sep 09, 2008 | Philips GoGear SA178 MP3 Player
    HELP HELP HELP!!!!
    Sounds like the firmware has corrupted. Install and run the Firmware Update software from the product CD.
    Select the repair option and follow the on-screen prompts. This will re-load the firmware and should get your player working again.
    Feb 20, 2008 | Philips GoGear SA178 MP3 Player
    Philips GoGear SA6025/97 Unknown Songs.
    philips go gear model no:-sa6025/97 required driver.
    my problem go gear not show my pc & other pc
    Jan 08, 2008 | Philips SA6025 Digital Media Player
    Philips GoGear SA178 MP3 Player Logo
    54 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
