Question about Franke Plumbing
Franke atm-400 faucet. When shutting off water, the water slowly stops rather than instantaneously like it normally shuts. Is this due to grit getting in the valve?
arealplumber
  • 33 Answers
SOURCE: Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
  • 10865 Answers
SOURCE: Greetings! My Kohler kitchen faucet
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Posted on Jan 21, 2009
  • 49 Answers
SOURCE: Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Posted on Jan 23, 2009
jj505
  • 195 Answers
SOURCE: single handle pull out Franke faucet stopped working
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
snap101
  • 117 Answers
SOURCE: water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Posted on Jul 31, 2009
Constant drip of water on my Franke manor house gooseneck bridge faucet. how do I repair the faucet from dripping water?
Check the washers and o rings that are a part of the faucet assembly. If possible tighten fittings.
Aug 23, 2017 | Franke Plumbing
Franke faucet FFPS200 has extremely low water pressure over the last few days. Same thing happened to exact same faucet in second home. How to repair?
You can check out the installation manual here that has a parts breakdown: https://s1.img-b.com/build.com/mediabase/specifications/franke/512399/ffps200_installsheet.pdf
Be sure to shut off the water below the sink prior to doing any disassembly.
Best of luck
Feb 24, 2017 | Franke Plumbing
How do i repair bellera #r560vs kitchen faucet reduced/low cold water flow have installed newfaucet valve
Turn off the hot & cold water supply lines at the shut-off valves.
Yo need to use the correct replacement cartridge for the faucet you are fixing
The cartridge replacement procedure requires using food grade silicone lubricant around the base of the new cartridge and around the threads of the bonnet.
Then you must properly align the 2 bumps on the bottom of the cartridge with the inside body of the faucet.
Insert and tighten down the bonnet that holds the cartridge in place to where it is snug- do not over tighten the bonnet!
Then reinstall the trim piece and lever.
Slowly, fully open the hot and cold water shut-offs and check for leaks at the shut offs, sink handle, and spout.
If you are using the Watts brand floodsafe supply lines, turn the hot and cold water shut-offs, on slowly. Rapid flow and pressure may activate the floodsafe valve within the supply line, causing little to no water flow to the faucet.
Feb 23, 2015 | Plumbing
LB2280 leak
If this is instant heat faucet, then contact manufacturer.
Most these faucets have 1 year limited warranty
Replace faucet?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 02, 2014 | Franke LB2280 Instant Hot and Cold Water...
I need a Franke faucet model # FF 822
I would try E-bay. Might also look for a rebuild kit. A last resort: Take it apart clean all the parts and then reassemble. Good luck.
Apr 01, 2014 | Franke Plumbing
LOW WATER PRESURE FROM A FRANKE KITCHEN FAUCET
There probably is sediment where the water is coming at the valve. Remove the head of the faucet and clean it . This normally is the problem.
Dec 24, 2012 | Franke FF-303 Kitchen Faucet with...
I have a very old Moen one handle shower faucet. For approx a month it was very difficult to shut the faucet off-it would push back and took several tries with a few seconds of waiting in between tries to...
I believe that is due to sediment that worked thru your pipes and caused the cartridge inside the diverter to act funny... as long as it's back to normal from regular use then you should be ok.
Water pressure inside your home has nothing to do with rainfall -- it's a combination of regular pressure as dictated by yoiur water company and the condition of your household pipes... older homes often have sediment and water pressure issues due to rust and calcium buildup inside the system.
Sep 01, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Glacier bay kitchen faucets with 2 handles and a sprayer
to be honest with you if there is a problem the glacier bay brand is from home depot and they are usualy around 20 to 30 dollars the replacement stems are usualy 15 to 40 depending on the part plus the hours ur gonna spend fixing it your better off with a full replacement. if replaced keep in mind you might want to replace the supliy lines to the faucet with stainless steal suply lines to ensure no leaks and if your shut offs are old dont touch them shut off your water main and drain down your house by opening all the faucets and shower valvs in your house then drain at the lowest point in the house weather it be a sink in the basement or an out side faucet once the supliy lines and faucet is in place then close all the faucets you opened and slowly turn on the water to your house slowly and this will ensure you dont have any leeks from your shutoffs good luck  your friendly plumber
Apr 12, 2009 | Plumbing
Plumbing Logo
90 people viewed this question
Top Franke Plumbing Experts
Jim Parker
Jim Parker
richie46
ray gallant
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
