Question about Sony KP-61S70 61" Rear Projection Television
Left half of picture has a green ghost like shade
    Scholar:
  • 130 Answers
The sounds like the light engine is bad. Sony is notorious for blobs because of the three LCD chip inside consisting of a red, green, and blue chip. The light from the lamp is reflected and then combined back together to form a brilliant picture. Unfortunately one of the chips is bad, or has melted due to extreme heat from the lamps. This can cause the color blobs on the screen. A lot of people experience blue or green blobs in the center or on the sides of their sets.
Posted on Feb 04, 2010
VIZIO M701D-A3R SCREEN GHOSTED WENT DARK OVER HALF
Aberrations of picture on these sets can usually be traced to a problem with the t con board.
May 26, 2016 | Vizio Televison & Video
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
The top half of my pictures with a flash are shaded.
Not seeing the pictures I have to guess. If the shade you mention is not like a straight line, but more rounded, try making the picture without the lens hood. Or use a external flash, when you use another than the standard lens. I don't think you can take a picture in manual, with a shutter speed above 1/250 second, because in such case the top or bottom part could become shaded then, but then the shade is in a straight line from left to right.
Dec 26, 2013 | Nikon D3100 Digital Camera
My JVC HD56 has a purple/green tint and isn't very bright.
Not worth attempting to fix and that is the reason it was tossed.
Apr 01, 2012 | JVC HD-56FN97 56" Television
Blue, red and green are very average quality but yellow is not visible. On a windows xp test page. the yellow is replaced with an orange color. A logo test page indicates some ghosting/shading - for...
Ghosting and shading on this series printers is usually caused by either a bad fuser or out of date firmware. There were fixes in firmware that stopped ghosting from happening. As for the cleaning the lens. These models have a bad habit of collecting dust on the inside of the scanner unit and the only way to resolve that is disasemble the laser unit and clean the inside of the lenses.
Mar 04, 2011 | HP Color LaserJet 2600n Printer
My t.v. picture was coming i ghost shade why?
If you are using antennae check the direction. If this is a cable input , then with a DVD , if all these show a ghost image, then the convergence of the TV section must be checked. Possible fault in the picture processing -( Y amp luminance)can lead to ghost images.
Jan 29, 2011 | Televison & Video
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony KP-61S70 61" Rear Projection Television Logo
170 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
