Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
SA999X wont turn off & smells
I have moved house and the oven is a 90cm SA999X smeg. a few months back the oven started popping the trip switch and an electrician checked it out and discovered that some wires had melted and it was leaking power and tripping out. He fixed that but now it started smoking a terrible smell and loads of smoke. i shut it off cleaned it, ran it again and it seemed fine but now when you turn the heat off, the timer off and the element off the light stays on and fan stays on. I have to shut it off at the mains. It still seems to heat up ok but does smell strange. Does this mean its on its last legs or do i take the electricians suggestion and replace the element and thermostate (rather expensive) and possible have the oven still die on me.
    President:
  • 1,462 Answers
Suspect your electrician wired it up wrong
Posted on Jul 18, 2008
Smeg 90cm burner tha lights up and goes off as soon as you let go the knob
For the oven burning cakes check the oven tempeture sensor for the top burner issue would check the igniter harness and the the igniter modules on the harness as well sometimes called spark igniters or infinite switches
Mar 07, 2015 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
Hi My power box just tripped and my oven turned off, prior to this happening it was working fine. I have a smegg oven model se378mfx5. It now wont heat up, it turns on ok but wont allow me to set the...
Feb 16, 2011 | Smeg Ovens
I have a smeg oven model SE335SS-5 I think that the element has gone however there is no obvious damage to the element. When I was cooking the house circuit breaker tripped and the oven works fine apart...
Feb 13, 2011 | Smeg Ovens
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
The light and fan works but no heat comes on in oven.
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
331 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
