Question about Yamaha EQ-70 Home Equalizer
How do i connect my Sony BDP S550 to my Yamaha RX V2400 receiver when so far, it is only connected to 2 floorstanding speakers and 2 bookshelf speakers?
  • 120 Answers
Through the tape in/out jacks and also push the tape monitor button when using the eq!
Posted on Apr 16, 2010
Setting up my rx v2400 to my tv
The setup may depend on your TV and other components and how you plan to use the system. Does your TV have analog or digital audio outputs? The receiver has analog and both types of digital inputs (coaxial and optical).
Use the best cables that you can. You can get all cables at online cable stores for much less than at the electronics big box stores. I'll assume that you already have the speakers connected to the receiver.
Next you can either connect your devices (cable box, blue-ray player) the receiver's inputs. Then connect the receiver's video out to the TV. This is great if you will only listen to the devices with the home theater system. Then you can also connect the TV audio out to the receiver for the OTA TV audio. For this you probably need component video cables and audio cables. These are all cables with RCA plugs.. Then get another audio cable for the analog or digital optical output of your TV. For some TVs the only audio out is the headphone jack. In that case, you also need a 3.5 mm to RCA adapter (the simplest is 3.5 mm M to RCA F/F for connecting to an RCA audio cable). For this method, you won't have to turn off the TV speakers most of the time; the TV won't have any audio.
Alternatively, connect each device audio/video out to the TV's input and then only connect the TV's audio out to the receiver DTV audio IN. Since the receiver doesn't have HDMI, this is the best option if your devices have HDMI out. For this, use the appropriate number of HDMI cables and the analog or digital optical audio cable from the TV to the receiver. Then turn off the TV speakers and enable the external speakers in the TV menu. You can connect to any of the receiver's inputs. If you use the labels, you'll find it easier to turn on the inputs.
If you have any devices with composite video output, use the same basic steps as for the component
The documentation for the RX-V2400 is available at the Yamaha product site: http://usa.yamaha.com/en/products/audio-visual/hifi-components/stereo-receivers/rx-v2400_black__u/?mode=model . You'll need to be a registered Yamaha user (Easy-Pass) to read the manual online.
I hope this helps. Please add a comment with your devices (including the model of the TV) for more specific information.
Feb 19, 2012 | Yamaha RX-V2400 Receiver
HOOK UP YAMAHA RECEVERS M-85
You would connect the rx-v2400 record output to the power amp input. You might need to Clarify your question here in more detail. Larry's Electronics
Apr 26, 2010 | Yamaha RX-V2400 Receiver
Receiver smoked, sizzeled and then quit
Throw on a couple of shrimp it and let us know when they're ready. You need a pro to look inside it.
Mar 19, 2010 | Yamaha RX-V2400 Receiver
How do I connect my Yamaha EQ-70 to my Yamaha RX-V2400 receiver?
from your receiver; R&L PRE OUT to R&L LINE IN of Equalizer.
And - from Equalizer R&L LINE OUT to Receiver MAIN IN.
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070.
Hope this helps!
Aug 10, 2009 | Yamaha EQ-70 Home Equalizer
My older Yamaha receiver has lost volume on the TV output.
if TV outputs are okay.Then simply connect TV into another input on reciver, AUX,TAPE,VIDEO ETC...if problem persist then output from tv is the problem..check settings on tv
Jul 29, 2009 | Yamaha RX-V2400 Receiver
120v plug in's on the back of my rx-v2400 will not send power to my mono block amps.
those are fused internally and made to power small items.the unswitched are constant power and the switched goes on and off with the power on the reciever.you have hooked it up to something that draws way to much power and more than likely blew the fuses.check the back by the sockets,they are rarely over 250 watts max.
Jun 12, 2009 | Yamaha RX-V2400 Receiver
Rx-V2400 Shut Down
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Oct 06, 2007 | Yamaha RX-V2400 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha AV Receiver RX V2400 - Shuts off
yamaha receivers protect themselfs when the power transistors at the output section are shorted, I just posted what you can look for this failure.
Feb 13, 2007 | Yamaha RX-V2400 Receiver
Yamaha EQ-70 Home Equalizer Logo
214 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
