Type of lubricant required for a hoover model 800 RLA gearbox
Gearbox consists of nylon and steel gears .this unit was made in australia approx 8 years ago
  • 15,935 Answers
Lithium grease.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
What is required fo gear box lubricant
Depends on the type of gear box,auto,s have transmission fluid ,manual gearboxes have differant grades of oil,check your hand book under spec,s.in the back.
Dec 03, 2016 | Cars & Trucks
Manual for hoover 800 RLA
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 19, 2011 | Hoover Washing Machines
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Auto box oil change Renault Scenic, gearbox stuck in park
Did you replace transmission filter? It may be blocked with dirt and is causing gears to slip...
Jan 26, 2010 | 2003 Renault 181
Nylon gear has several of its teeth. 2 gears are
For parts advice call Royal at 1-800-524-0799.
Dec 10, 2009 | Royal 150MX Cross-Cut Shredder
Need parts for traveling tractor where can I get them?
Have you tried their website? These sprinklers are relatively expensive units as I remember. Well made and well worth fixing. Usually nylon gears with stainless steel shafts. Parts should be available through Nelson. Google: Nelson Traveling Sprinklers and see what sites pop up. If this has been helpful, please rate it accordingly. Good luck.
Jul 15, 2009 | Nelson Sprinkler: Traveling Tractor
Hoover 800 RLA washing machine spins slow or not at all.
It sounds like the electric motor is dying!
Either pay a serviceman to come in to confirm this or buy a new machine.
New motors can cost anywhere from $380AUD to $600AUD.
Jun 17, 2009 | Washing Machines
Whirlpool Washer Model:LSN1000KQ0,SER: CM4267948, Type: 111 - Need nylon gear in transmission gearbox.
From the information provided, it sounds like you need WPL 285362 (gear and pinion kit) which you can find at appliancehelp.com for $59.95. You can type in your washer model and see the diagram of each part before ordering so you get exactly what you need.
Apr 16, 2009 | Whirlpool Clothes Washer Timer Knob -...
Whirlpool toploader gearbox/clutch removal
Last Night I took the machine apart to find clutch/brake assy ok gearbox was also ok then I noticed shaft coupling was different than new part I had in stock, new part made totally of nylon, old part fitted to machine has steel insert built into nylon. this was not fully located onto motor shaft and the first 1/4" of motor shaft had been stripped back to round ( no flat faces) also inside the steel lined bore of the nylon coupling had been worn to round.I replaced with new coupling of nylon and ensured both nylon parts fully pushed home onto motor shaft and gearbox shaft with any freeplay / gap being allowed in the rubber drive link. This has worked for now but expect trouble in future with worn motor shaft.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
