Question about Drills
For several yrs my husband has had a DW927 12v 3/8 cordless adj. clutch driver/drill (type 1) never had a problem. this was his dependable drill.then it just seemed to lock.the chuck didnt want to budge and the trigger switch was stiff.i took it apart to clean and inspect. some parts were lose but nothing appeared broken...just very dirty. i cleaned thoroughly and began to re-assemble. i should have taken a few pics! now i have a piece left over and i know its vital. its a channel shaped rectangular metal clip, (the length of a dime) the two sides are rolled at top edge and have cut-out tab near bottom. can you picture this ? i sure have something messed up cause the trigger won't move at all.i'm hoping the little metal clip is the only problem. is there an 'explosive diagram' of this drill?(a schematic type)if i could just see a diagram, i could do it. can you help?
  • 3 Answers
Hi Tootsie.
I am an electrician and I have (5) of these. I ran into the same issue when I rebuilt my first one. #1> the metal clip you may have is about 3/4" long and about 1/4" wide? If so, that is the SPARE bit holder that lives on the bottom of the handle. #2> The metal clip ,you may have, is rectangular and is molded. It measures app. 1/2"X 3/4". If so, this lives within your,"SPEED SWITCH CAP". It is used as a retainer.. As for your trigger, if centered, it reacts as a stop position for the motor. This is a safety precaution to reduce DOUBLE POLARITY and prevents shorting of the battery and trigger. Make sure that you have installed it correctly and that it moves FREELY. I have done this before myself......It's the small things that make a difference...............! Take Care........
Posted on Feb 05, 2010
Testimonial: "this info has been very helpful. yeah you're so right about the part. just found it in the diagram.now i'll tackle the project. thanks"
The clutch is slipping how do i fix
If its clutching out in drill mode the clutch pin is worn. This part is 635718-00 its only a couple bucks. not hard to repair either bout 5 min.
Sep 07, 2011 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Correct clutch setting for driving screws
This depends on the softness / hardness of the timber you are driving the screws into.
Start with midrange clutch setting and when clutch slips, adjust the setting upwards until screws are driven fully home.
Feb 18, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
Cordless drill question
1/2"
A 24 position clutch controls torque output. 2 speed range gear box for high torque applications. Auxiliary handle with metal depth stop rod. Has an overmold grip handle for added comfort. A Mag Tray holds screws, small bits and hardware, etc. on foot of drill for easy access. 1/2 Ft.' heavy duty keyless chuck for quick and easy bit changes. Removable 2 position level for convenience and accuracy
Apr 19, 2010 | Ryobi 18v Variable Speed Impact Driver...
For several yrs my husband has had a DW927 12v 3/8 cordless adj. clutch driver/drill (type 1) never had a problem. this was his dependable drill.then it just seemed to lock.the chuck didnt want to budge...
Here is the diagram. I've been having trouble pasting them into dialog bax so I will include the link where i got it.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pnghttp://www.ereplacementparts.com/images/dewalt/DW927_TYPE_1_WW.gif
Feb 04, 2010 | Dewalt heavy - duty 3/8" 12v cordless...
Have a workforce brandname drill/hammer cordless that the charger no longer works is there any place that still sells or repairs these in nova scotia canada
Replacement batteries for the Workforce 18V cordless drill are available @ 888-315-3080 for $15.00+
I currently have 2 on the way via UPS
Note: This drill is no longer marketed under the WorkForce name (and Home Depot won't help you) but is marketed under several other names including Hillman.
Jan 24, 2010 | Hitachi 12v 3/8" Driver Drill Kit with...
I lost the charger for the 18v PSO1800 Type cordless drill
Replacement parts in USA from
http://www.ereplacementparts.com/charger-p-100122.html?osCsid=cv3pj4ntur724eevbt3vhfeor4
does not appear to be a UK model.
Nov 17, 2009 | Drills
Adj.clutch
those numbers have nothing to do with speed.
They are torque setting for the drill, so you don't overdrive the screw in....the smaller the number, the less torque.
Plz don't take you drill apart
Sep 26, 2009 | Drills
Dewalt 18v drill dc988 type requires switch
Here is a link for a parts diagram for your model. It has the proper part number that you will need.
Hope this helps.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/dewalt/DC988KA_TYPE_1
Sep 07, 2009 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Jan 19, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
78 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
