Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
On drier cycle machine left a pool of water at the back of machine. We switched it off and when an elec. There wastrician turned it on there were some sparks and now it doesn't go. There was still power on the socket feeding the machine
  • 129 Answers
Call manufactor to ck warranty
Posted on Feb 04, 2010
Gas burner cycles on & off
It is supposed to cycle on and off as the water enters and then heated and then released from the unit. To see if it is working properly, you need to measure the input water temperature and then the output water temperature. It should be about 10+ degrees difference.
If it isn't then give us some more symptoms to work with.
Jun 01, 2011 | Teledyne Laars Laars Lite2 Heater 400000...
I have a Whirlpool LXR6232EQ0 washing machine. Today it can filled in water and washed, but when came to the Rinse cycle, no response at all. Water will not be drained and not even hearing any click or any...
check the lid switch, it is located on the back left of the lid and the top left of frame. try to tighten the two screws on the location of switch(sometimes the lid switch gets loose). Another way to check find switch and the lead wires to it(2) of them, remove ends from switch and connect them together and try cycle.
Oct 02, 2010 | Washing Machines
My Jandy Laars Natural Gas pool heater (LJ250N)
Check your heater by-pass valve and be sure it is almost closed. If not that then it will be your internal by-pass. These will force water through heater and keep it from overheating the water inside it and shuting it down. Also check to be sure the baskets are clean and the filter is clean.
Jun 27, 2010 | Zodiac Jandy Lite 250K Btu Natural Gas...
Washing Machine Stinks
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Nov 21, 2009 | Dryers
Pool heater will not turn on, elec. power good, switch good, gas on water flow good. Found no burnt out parts. 50,000 btu heater for spa./?
Check the limit switch. It may be stuck open and if it is it stops the unit from running. Also check thermostat setting and make sure it is working. Make sure the flame sensor is working. The system will start sometimes but if the flame sensor doesn't see a flame it shuts down. Good luck...Lee
Nov 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Washing machine tripping elec's
Sounds very much like the program PCB (printed circuit board) needs replacing.
A job for a qualified engineer I'm afraid.
Sorry.
Feb 27, 2009 | Creda W120VW Front Load Washer
Long drying times model #11062712100
Try this and let me know what happens.
TIP OF THE DAY
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Feb 07, 2009 | Kenmore 73952 Gas Dryer
Opened dryer door mid-cycle left open 1 hr. Dryer won't restart
there is a door switch on left upper corner of drier opening, make sure the little prong is clicking when you push it in. this turns the drier back on when the door is closed and the start button is pushed.
Dec 31, 2008 | Kenmore 63942 Dryer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
69 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
