Question about Cameras
After going to menu, i went to format, and clicked the side, yet didn't press anything else, and automatically it said PROCESSING, i wasn't real sure of what i did, so i turned off the camera right away. After i turned the camera back on, and trying to view photo's the screen said NO PHOTO.
  • Cameras Master
  • 6,487 Answers
Base from what the camera is saying now that there's no photo inside it the format process was completed and we don't have any option now but to do a data recovery on it. You can use this software in doing a recovery its called Recuva, download it from this link and then install it to your computer. Once already installed to your computer connect the camera to your computer and start the Recuva software and enable deep scan for the camera and there that should be able to recover your lost photo.
http://download.cnet.com/1770-20_4-0.html?query=recuva&tag=srch&searchtype=downloads&filterName=platform%3DWindows%2CWebware&filter=platform%3DWindows%2CWebware
Posted on Feb 04, 2010
Tip
How to format a hard drive in windows XP
When you format a computer hard drive, you will lose everything that is on the drive. Therefore, it is very important to back up anything you might want later. Also you need to have the operating system that you are going to be installing after the format (so make sure you do) . Backup anything that you don't want to loose on a seperate cd, dvd, or external hard drive that you are not going to be formatting.
Now first of all, Right-Click on the "My Computer" icon either on your desktop or in the Start Menu and select "Manage", a new window titled "Computer Management" comes up. Select "Storage" from the left hand side by clicking it once, then select "Disk Management(local)" from the right side by double-clicking it.
Now in the lower part of the main frame of the window you should see a nice visual of all your hard drives. Each line is a different drive. Each box on a line is a partition on the drive. Partitions are separations of space on a drive. Unless you are doing something specific that requires multiple partitions, you only want one partition per drive.
First you must delete any existing partitions on the drive you are going to format. Do this by right-clicking on the partition's box and selecting "Delete Partition.. Click yes for the prompt "are you sure", and whatever other warnings you might get, as long as you have backed up everything you need.
The box for the drive to be formatted should now have a black bar at the top of it and should say "Unallocated" under its size. Right click on it and select "New Partition..." The New Partition Wizard comes up.
In the New Partition Wizard click next. On the next page make sure "Primary Partition" is selected and click next. Now make the size equal to the maximum (it should already be set to it), and click next again. On the next page the computer will automatically choose the first available drive letter for the new drive. However, if you like you can choose another drive letter from the drop-down menu, and then click next. Finally the New Partition Wizard asks if you would like to format the new partition and if so what format. Choose "NTFS" as it is faster and more secure. Leave the "Allocation unit size" as "Default." In the "Volume label" field enter whatever name you want the drive to have. After that, check the "Perform a quick format" box (If the drive has been used before you can leave this box unchecked). Leave the "Enable file and folder compression" box unchecked and click next. Then on the next page click finish. The wizard will now spend a little while formatting the drive. On old or large drives this may take a while. Do not close the "Computer Management" window until it finishes. You will know it is done when the word under the size of the drive changes from "Formatting" to "Healthy" and the name and drive letter you chose for the new drive show up. After it is finished you can now use your newly formatted drive.
on Jan 14, 2010 | Computers & Internet
How to format nokia 5310
You can manually format your mobile. For that, go to the phone settings, select phone, after that select restore factory settings. Now press Ok. Now enter the default phone code which is 12345 or 00000 and press Ok. You have completed the format process. If this doesn't works then visit your nearest service center.
Mar 10, 2011 | Health & Beauty
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
When i take pictures rapidly the screen says ''processing'' , often for up to10 seconds or more. this happens with a 2 gig non hi def card and 8 gigHD card. regardless of pixel setting.this has just...
It could be caused by your SD card needing to be formatted.
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
Scroll up or down to the Format option, then press the OK button
Jan 25, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Card not initialized
If this a new memory card, you can try to FORMAT it. Formatting will erase any contents on the card.
Use the right arrow and select the "options" menu. Press the up arrow to select "set-up", press "menu/ok". Select "format" on the menu using the down arrow. Highlight OK on the screen click "menu/ok".
Jan 06, 2010 | Fuji FinePix A350 Digital Camera
SanDisk 2GB memory card
format the mem card through your computer instead maybe, it works best if u have a usb reader that the sd card slot in then jus plug it in. if it dont automatically show up on pc go to 'my computer' in the menu and it should b found there prob as removable drive, once in it right click mouse and should b an option to format sd card, hope this helps.
Apr 10, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Boot in TASCAM 2488
thiagofo,
Formatting of the hard drive is outlined on page 66 of the 2488 manual (assuming this is the old grey 2488 and not the newer blue MkII).
In case you don't have the manual handy, you can either format the entire drive (excluding the fat partition) or just one of the partitions. There is also another option to refrormat the fat partition.
To format the drive, (and create new partitions), go to the 'disk' menu, highlight 'format' and press 'enter'. You'll be asked to specify the new partition size (all partitions will be the size you choose). The press 'enter' again to proceed with the format. A new blank song will be created on each partition. Do not power off the 2488 while the format is in progress.
To format a single partition, from the 'disk' menu choose 'reform' and press 'enter'. You then choose (by highlighting) which partition you want to format and press 'enter' to format. You'll get the warning/confirm message and press 'enter' again to proceed.
The fat partition (visible via usb from a PC) can be formatted also. To do this select 'fat reform' from the disk menu and press 'enter' and then 'enter' again at the warning.
irvingsr3 - I'm not sure if resetting the unit is the easiest way to fix your problem. You might be able to perform a redo, or you might be able to just go and start a new song which will reset most of the control settings to their defaults. When you hit 'undo' it may have rolled back some of your input assignments or tracks which were armed for recording and that could explain why you can't seem to record now.
bd.
Jun 23, 2008 | Tascam 2488 Portastudio Multitrack...
EX-S880 Shutdown
First off make sure that the battery when charging is a solid red light and NOT flashing. If it's flashing that means we have a problem with the battery.
Make sure you are only using a Toshiba, Panasonic or Sandisc memory card that is no larger than 1 GB unless you did a firmware upgrade to handle a larger card.
Take your memory card out. Turn the camera on and press menu, go over to setup, go down to format (this will format anything on the internal memory of camera) and press right arrow to highlight format and then press ok button. It will say busy please wait and then once that's done please press menu again, go to setup, go down to reset, press right arrow, highlight reset and press ok.
If the camera is still acting up after doing this please contact Casio repairs and they can fix it for an electrical issue.
Apr 27, 2008 | Casio Exilim EX-S880 Digital Camera
I need help with my mp3 it wont let me listen and i already tried to format it and it did not work. it still says not enough space for music db please free 8 MB. and then it says no files and my computer...
Your M230 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M230 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M230 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M230. The lower section also contains the drive # pertaining to your M230. Right-click on either drive letters pertaining to the M230 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M230 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M230 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M230 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M230 is a great player
Apr 15, 2007 | SanDisk Sansa m230 MP3 Player
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
