Question about Philips 47 in. LCD HDTV
Philips 47'' LCD TV will lose sound and picture for a few seconds then come back. I have a dish network HD receiver hooked up through a HDMI cable. Sometimes it will go days with no problems, sometimes it will do it 5 times a day.
  • 1 more comment
  • caetano340 Feb 05, 2010
    Even if it only happens with the dish network receiver? It works fine with the dvd player.
    The power light stays on. I tried 2 different cables and the same issue. I tried different HDMI ports and it did the same thing. The screen goes black, but you can tell the tv is still on. The picture and sound then comes back on its own, works fine for a while, then does it again. Again, sometimes it will not do it for a day and sometimes it does it 5 or 6 times a day.
  • caetano340 Feb 07, 2010
    Could it be a HDCP Handshake problem? It seems to go away for a couple days when I reset the receiver. Then a few days later it will do it again.
  • 148 Answers
Hi there, they problem is not in the input to the tv (dvd/cable etc) your powerboard/videoboard is overheating! Right away place a fan as close to the back of the tv as possible, this will help cool the circuits down and might considerably prolong the usefullness of the tv..The next step in it breaking down is total powerloss, or a blinking powerlight, eitherway this is your solution;The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not )please rate, thank you!Philips 47 - d4195d7.jpg
Posted on Feb 04, 2010
  • roadtrippin Feb 05, 2010
    Hi there, and thanks for the rating (now I'll do my best to earn it :) )
    To further you in the diagnosis of your problem I will have to ak a few questions, but it will quicken our process...,I need to know if the powerlight on the tv is on or off or blinks when the tv shuts down on its own...The problem could be in the wiring to the inputs ( bad 'pins' in the connectors), low grade cables etc....try wiggling or unplug and replug the cables to and from the tv and any connecting media (dish, cable box, dvd)...except the powercords...Any changes? ...Hope to hear from you and while I am waiting for your response i will check further into this problem!
    I don't believe it it a backlight problem, the sound wouldn't go out at the same time. These problems are very common, but I have not ran into many problem like this, that were not related to a broken capacitor. One of the causes of lcd tvs (or monitors) randomly switching off and back on, are 1 or 2 bad capacitors, but since you've eliminated these, I will have to do further research and create a checklist for us to go by...I shall return!!.....Meanwhile, if the tv is still in use, study any sounds/ picture changes and anything else that could seem to be of use for me...
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
Cannot get it to provide a picture when connecting it to my dish network reciever, neither through hdmi input or my a/v cables
This can be a really frustrating problem, but I hope that you have gotten this resolved. If not, here are some steps that might help you out.
When you are using the RCA cables, you want to connect them on the back of the receiver where there is a green TV symbol with a 1 in it. You will want to make sure that your TV is on channel 3, and then slowly cycle through the inputs. It can take a few seconds for the inputs to change, so wait about 10 seconds on each input. If you still get no picture, try to go to channel 4 and do the same.
When you use HDMI cables, it is close to the same process. You will need to be on an HDMI input. Again, wait about 10 seconds on each input. Try this first on channel 3 then try 4 if you have no luck.
Feel free to email me if you have any other issues!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | Dynex DX-LDVD22-10A 22 in. HD-Ready LCD TV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Hooked up our Vizio to dish network. but have had a problem with buffering. The picture will freeze and then start up again. The HD Movies would have the lips moving out of sync, I have went into the audio...
Hello, there are a few things that could be causing this. Usually when this is happening, we have you unplug the receiver from the outlet for about 10 seconds, so if you have not done that yet, go ahead and do so. The receiver will sometimes do that, and it just needs to be rebooted. Cabling can sometimes be an issue as well. The quality of the cable can be an issue, or if the cable is a little loose, that can cause it as well. So I would try another cable, it doesn't have to be HDMI at the moment, just to see if it happens with the new cable as well. You can email me at becki.barned@dishnetwork.com if you have any other troubles.
Becki Barned
Mar 05, 2011 | Vizio VO47L 47 in. LCD TV
Have vizio tv trying to hook audio out puts of tv/dish network for component usei nto my stereo receiver what do i do
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the stereo receiver where it says "in" or "input".
Next take another cable and connect it from the stereo receiver output to the TV.
Daniel Busa
Feb 06, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
I have my tv hooked to a hd dish network sat box but I i only receive 480p instead of 1080p.
Hello there!!! There are a few reasons this could be. The first step would be to check how the hd is set up on the receiver. Press Menu 6-8. You will want to make sure that the Tv Type says 1080p. If this does not work, make sure that you are, of course, using an HDMI cable, or component cables. If you are having any other troubles with this, you can e-mail me at becki.barned@dishnetwork.com.
Becki Barned
Dec 12, 2010 | Vizio XVT553SV 55 in. LCD TV
I have an longtime problem with my flm 3232 polaroid hdtv. I have dish network service with the dual receiver. The 3232 is the second tv connected via a coax cable. it work fine on the tv cable input...
Hello, you probably already have gotten this resolved, but I do have some answers to your post. Any cable that you have running from TV1 to the TV2 will nor give you a true HD picture. You could get a CAT5 cable with HDMI ends, but the longer the cable, the less true HD you have. The best resolution to this is to get an additional receiver, or to just stick with the SD picture. If you have any more questions, feel free to e-mail me at becki.barned@dishnetwork.com, or you can find us on Twitter!
Becki Barned
Oct 14, 2010 | Polaroid FLM-3232 Television
I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
Nov 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
Philips 47 in. LCD HDTV Logo
438 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
