Question about Saeco Royal Professional Espresso Machine
How can I make the milk hotter using the cappuccinator?
  • Saeco Master
  • 1,711 Answers
Yes you can make a small trick for that. You can use a sqweeter on the milk silicone hose so the milk can flow with more dificalty as long as you can see milk flowing this can be up to 78 C . You should keep the cappuccinatore very clean since you will need the steam to come as easy as possible
Posted on Feb 13, 2010
THE FORTHED MILK NOT HOT
Try steaming less actual milk and allowing the froth and expansion to make up the volume you need for the size of the cup. This allows you to steam the milk longer achieving a hotter froth.
Dec 20, 2014 | DeLonghi Magnifica Coffee Makers &...
Wet steam, poor pressure
Have you tried cleaning the steam wand nozzle with a paperclip (or the pin tool mounted in the back door of the unit?
Milk deposits can make their way inside the nozzle and block it, describing the symptoms you're getting.
Apr 12, 2014 | Sunbeam Cafe EM6910
I have the via veneto model that has the rubber tube that draws the milk in. It doesn't seem to build enough pressure now to do it. I have been cleaning and descaling it on a regular basis. The expresso...
Hi
There is a pin on top of the cappuccinator the will twist to create suction. Turn it slowly when steaming until it starts to draw milk up to foam. Then leave it. If you don't have the pin, thats your problem.
Jan 02, 2011 | Saeco VIA Veneto Espresso & Coffee Maker
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
Jul 09, 2009 | Saeco Royal Professional Espresso Machine
Steamer is not getting hot enough.
Try using the milk clamp on the tube going into the milk.Tightening it will make your milk hotter.
Your steam wand however, is a different problem.
First, check in the programming that the steam temp. is 125 celcius.
If it is, and none of the tubes from the steam wand to the boiler valve are blocked, your boiler temp. sensor may be faulty, in which case, you will need to replace that.
Mar 13, 2009 | Nuova Simonelli Microbar Espresso Machine
Primea ring hot milk
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Hotter coffee
can also - press menu untill temp comes up - set to high.
(only low med and high)
Mar 01, 2008 | DeLonghi EAM3200 Espresso & Coffee Maker
Saeco Royal Professional Espresso Machine Logo
219 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
