Question about RCA D52W19 52" Rear Projection Television
I believe it got some water dmg from water dripping from the ceiling. Can it be repaired? It makes a clicking sound when you turn it on, but it shows no picture.
    Problem Solver:
  • 6 Answers
A clicking sound may be a ballast that can't ignite the lamp.
Posted on Feb 04, 2010
    Scholar:
  • 130 Answers
That might be the ballast trying to ignite the lamp. You may have some serious problems. Have you tried replacing the lamp yet to make sure that ballast is good? If not, then you need to check the lamp then the ballast.
And also the power supply may be bad. You can open it up and take a look to see if the power supply has any blown capacitors too. A blown capacitor will look like an upside-down battery mounted to the board, but with a bulge out the top.
Shower dripping
The shower drips because one of the water shut off valves is leaking. The video linked below will show you how to make this repair much better than typed words can. See
How To Fix or Replace Leaky Shower Valve Stem Seal
If replacing the seal does not cure the problem, then the entire valve stem needs to be replaced.
Mar 13, 2015 | Home
Hear water sloshing around behind dashboard in 2008 Dodge Avenger
Wonderful.
Share a website with you ,
( http://www.alib88.com/ )
Believe you will love it.
We accept any form of payment.
http://www.alib88.com/Michael-Kors-Handbags-n2447/
May 31, 2013 | Cars & Trucks
The fridge is dripping water from the top ceiling in the fridge and the fridge itself is making a terrible noise. We unplugged the fridge for four hours and now it is quite however there is ice covering...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Jul 28, 2010 | Frigidaire FRS26R4A Side by Side...
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Hi, Have a situation. My bath tub(2nd floor) is leakinge and water is dripping down to my living area (through the lower level cieling). 1) I ran the water and collected it in a bucket to see if it water...
You will have to bust out the ceiling where the dripping is occuring to get to the pipes. Before doing so, check and see if your house was built with an access door for the valves. (Look on the other side of the wall where the valves are.) I have the very same problem and am going through ceiling replacement after repairing the pipes. It is a mess. Good luck.
Nov 30, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Leaking water into bottom of fridge under crisper drawers
This is often caused by a drip pan from the defroster in the freezer that is "missing" the drip funnel in the refrigerator. This can be a bit dicey to fix because you have to take the ceiling off of the refrigerator section and then drip some water in the freezer section. If you're lucky, you'll find some crud in the drip funnel. If not, and you can see it happen, you'll find the water go somewhere else that is not intended, like following the back panel down instead of properly dripping. Make a little copper wire "water director" where the water will follow this copper wire. The whole secret to solving this problem is to see what the water is doing.
Nov 29, 2009 | Kenmore Refrigerators
Kenmore refrigerator model 363.9711781 water appears daily
This water comes from a plugged up defrost drain tube. Do you see like a cup at the back of your refrigerator connecting using a plastic tube in a hole at the back of your refrigerator ? This cup collects dripping water from your freezer during a defrost cycle - you will notice a hole above it on the ceiling - what drips into this cup and drains out back the hole in your refrigerator wall and into a long drain tube extending down into the drip pan at the bottom of your refrigerator, usually sits ontop of the compressor or in newer systems next to the condenser fan and evaporates. If this drain tube is plugged up with debris water will backflow back into your fridge and drip against the wall and under your cripsers.
During a defrost cycle (when you hear the sizzling sounds and all motors are off, open the door and you should notice water dripping.
If you can manually remove the cup yourself you can pass a piece of pipe cleaner or long cable and dislodge whatever is blocking it or if you can't do that you will need to have it serviced, sometimes there is a seal around base of the plastic tube it's best you don't touch or break it. Makes ure the cup is firmly connected and inserted into the hole, you can try raising the fridge a bit, the front part so it is slightly inclined to back. If all fails, have it serviced, it is a very simply problem easy to repair and common too.
Aug 24, 2009 | Kenmore Refrigerators
Shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
May 28, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Jan 17, 2009 | Frigidaire FRS3R5EMB Side by Side...
RCA D52W19 52" Rear Projection Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
