Question about Sewing Machines
Need service manual for Kenmore sewing machine 158.19142 I have had this machine for at least 30 years. It has been a great machine. It has cams you put into the top for different stiches but it does'nt seem to be be working right anymore and I'm the only one that sew on it. I took it in to a shop about a year ago but they did nothing. So I thought I would look on the internet and find a repair manual for it. I really love my machine, they just don't make them like that any more. Can anyone out there help me with a repair manual. I would really appreciate it. Thanks. looking forward to hearing from you all.
SOURCE: thread a kenmore 158 13410????
Not sure if I am too late, but it's pretty basic. I have the same machine...
You have the thread on the spool with the thread on the left side (unrolling off the spool counterclockwise) and put it around the round thing on the front middle (looks like a snap sort of) and through the eye almost right in front of it (the loop) and hold the thread lightly then wrap the thread around the tensioner (the thing with the dial) to the left (counterclockwise) until the springs "pops" it into place. Then run the thread through the little hook thing (by entering from the left) then up to the eye (hole) that is in the little arms that raises and lowers (you might need to spin the wheel to get the arm in the right position) then you run the thread back through the hook thing (entering from the left) around the little half circle thing (by entering from the left) and finally in the hole in the needle...
hope it made sense, I tried to use laymen terms...
good luck!
Posted on Jul 09, 2008
  • 69 Answers
SOURCE: Kenmore Sewing maching 158 15510: sewing mechanism
You put the hook (the half moon thing with a sharp point on it) in the machine by placing it opposite the little curved bar. Make sure it is seated properly on the ridge. The you take the race, the circular part with a small plate on the top and place that over the hook(the plate side will be facing up). It will only fit a certain way, it could have a slot that a notch fits into (that is usually how it goes). Then slide the arms over it and they will snap into place. Once done, turn the handwheel and make sure everything moves smoothly. If not, you'll need to start over as something isn't seated correctly. Then you can install the bobbin case as usual.
Posted on Mar 01, 2009
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
SOURCE: can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Posted on May 02, 2009
SOURCE: I have a quantum cxl.
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Posted on Jul 02, 2009
Need kenmore sewing machine 158.17600 manual and how to locat and purchase cams
Check with Sears. They carry a lot of manuals for Kenmore machines. As for the cams, they probably are no longer available unless you can find them for resale, ie eBay, etc.
Sep 30, 2017 | Kenmore Sewing Machines
Kenmore 385.18221 auto bobbin shut off does not work how to fix? where to get repair manual?
Hi Freysauto,
You can obtain the Owners Manual here: Instruction Manual Kenmore 385 18221 Models
'Manage My Life' reports "There is no service manual offered for your model sewing machine. Some of the older sewing machines didn't have an owner's manual and service manuals were offered for them. There is an owners manual for your sewing machine, but no service manual." Can download service manual for Kenmore sewing machine 385 18221...
Good luck.
Feb 12, 2015 | Kenmore Sewing Machines
I have been looking for 3 days! Still can't find the manual for the Kenmore Sewing machine model #148.13110! Please can someone HELP terryrp@icloud.com
Unfortunately, the manual is not available for free. Sew USA, http://www.sewusa.com , has various Kenmore sewing machine manuals available. I believe the manual you need will cost $10: http://www.sewusa.com/Sewing_Machine_Manuals/Kenmore_Manuals/Kenmore_1311_Instruction_Manual.htm .
I hope this helps.
Dec 02, 2014 | Kenmore Sewing Machines
Kenmore 1601 manual for cams
The cams are at the top their is a screw that you change the cam with go online for a manuel.
Aug 26, 2014 | Sewing Machines
I need an owner manual on the kenmore model 12102 sewing machine.
I just discovered that you can go to www.managemylife.com and under manuals, put in 385.12102 and you can have a free copy of your maual. Hooray, this is a great find because normally you have to pay for it. Happy New Year. Good luck
Jan 03, 2011 | Kenmore 12102
Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Jan 24, 2010 | Sewing Machines
How to use white cams
hi! there,
white cam plate are mounted on top side of your machine there
is shaft for mounting on figure the plate cover opening for cam,then adjust the dial for the neccessary cam designed.32e83f9.jpg
you have to replace the presser foot on figures.5af54f1.jpg this presser foot is more convenient to use on designed cam
the stitch adjustment should # 8 to # 12 just select w/c more convenient to yuo,dial tension set to # 3 to # 6.
have a nice day,don't forget to rate me,thank's
Apr 26, 2009 | Kenmore Sewing Machines
Where do I oil the sewing machine?
OILING
FACTORY LUBRICATED PARTS WILL PROVIDE YEARS OF HOUSEHOLD SEWING
WITHOUT ROUTINE OILING. HOWEVER, WHENEVER THE MACHINE tS BEING
SERVICED, CHECK TO SEE IF ANY PARTS NEED TO BE LUBRICATED.
OIL
APPLY GOOD QUALITY SEWING MACHINE OIL TO THE POINTS (A, B, C, D, E)
INDICATED BY BLACK ARROWS.
GREASE
WHITE GREASE IS RECOMMENDED FOR USE ON GEARS AND CAM SURFACES.
IT IS AN IMPROVED GREASE, AND IT CAN BE USED ON THE METAL AND PLASTIC
PARTS WHICH POINTS ARE INDICATED BY THE WHITE ARROWS (F,G, & H).
HOW TO ORDER
PARTS NO.
EM / 40M
DESCRIPTION
SEWING MACHINE OIL
WHITE GREASE
Apr 12, 2009 | Kenmore 15358
Kenmore sewing machine model 15817740
I rooted around and finally found the manual and all the attachments for the buttonholer. Thanks anyway.
Apr 12, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
