Question about Hotpoint Dishwashers
Dishwasher wont' drain ...leaves dirty brown water ing bottom of washer
  • 129 Answers
Remove drain hose under sink shop vac hase pump and sewer drain clean out inside washer food chopper in bottom rear of washer
Posted on Feb 05, 2010
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Dish washer wont empty out leaves about 2 or 3 in in it
Drain hose clogged or Not ran in the proper draining position, under the sink where the hose ties into the drain system or garbage disposal, the hose should be higher than the connection point, I have fixed this by tie strapping hose to the bottom of the counter or sink, hope that helps ?
Feb 27, 2015 | Kenmore Dishwashers
How to diagnose the problem
check the outlet pipe to see that the water can flow easily, not bent. It looks like that the dishwasher is unable to drain the water through the hose.
anna poorani
Jun 30, 2014 | Samsung DMT800RHS Dishwasher
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
Does not seem to drain. Always leaves a couple of inches of dirty water. Also leaves a lot spots on dishes.
Check the float in the bottom of the washer. If it's stuck it could cause problems. Otherwise, maybe the pump that lifts the water up and out into the main drain isn't pumping properly.
Feb 11, 2011 | Frigidaire Dishwashers
Cycle does not finish leaving dirty water bottom of tub without draining out
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 12, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwasher drain pump flapper (inlet side)
My Quiet Series does the same thing and I wondered if the orange flapper has gone bad and lets the dirty water drain back from the hose sloping up to the garbage disposal. Did you get an answer to this question? The dishwasher seemed to work fine and then it suddenly started leaving food particles on the glasses.
Jan 15, 2010 | Dishwashers
Water not draining from the bottom of the dishwasher
vacuum it out with wet/dry vac and see if filter is dirty big peices of food will accumulate and stop it up if not check under sink where drain hose connects to main drain
Feb 19, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
527 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
