Question about Maytag PAV2300 Top Load Washer
Put new motor and pump on washer doesnt agitate right and I have to put on spin at least three times to spin water out
  • 129 Answers
Needs new spring on motor and new belts i would also replace pully assembly
Posted on Feb 04, 2010
Water will fill (and drain), was agitating - then stopped with a loud buzzing. Water will still fill and drain, but will not agitate or spin. When it should be spinning or agitating, the loud buzz is...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Sep 15, 2010 | Kenmore 25842 Top Load Washer
I have a kenmore elite model 23022 and when it starts draining the water right before the rinse cycle it has a loud whinning noise. Could this be the pump? It only does it when the water is draining out.
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
It is possible that it is the pump but I'd check some other things also.
These washers use a reversing motor when going into drain / spin mode. Since the pump is always connected to the motor, while agitating the pump turns one way (keeping the water in) and when the motor reverses, the pump spins the other way, suctioning the water out
Three other possibilities:
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
It's also possible that the Neutral Drain Assembly in the transmission is broken:
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Ours had a similar problem.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
All of the above sound more difficult than they really are. If you're comfortable with a socket set, pliers/vice grips and willing to get a bit dirty (oil) you can save some considerable money.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Jul 08, 2010 | Kenmore 23022 Top Load Washer
My 2090 Kenmore model washing machine (serial #cj3302826) is slow on the spin cycle. If any clothes are on the agitator,it will not spin. Remove clothes off and along the edge, it will spin. Also, does the...
As far as the agitator spinning during the spin cycle:
It's not supposed to. It may spin simply because of the oil in the gearcase turning the agitator shaft but it shouldn't be driven by the gearcase. See the following Whirlpool Service Manual on how the transmission / gearcase works.
What should happen is:
When the washer goes into spin mode, the gearcase reverses direction moving two plastic cams (Agitate Cams) together which push up against a spring which lifts the agitate shaft away from the agitate gear.
If the agitate cams (about $12.00) are worn (not necessarily broken) they may not lift the shaft high enough (about 1/8") so that the agitator will spin along with the drum.
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
If you suspect the agitate cams:
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
May 18, 2010 | Kenmore 24902 Top Load Washer
My kenmore washer will not agitate or spin. It makes a noise when it is trying to agitate the clothes or in the spin cycle.
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
May 11, 2010 | Kenmore 24032\24036 Top Load Washer
Washer hums when turned on will fill with water
This is the most likely problem.
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Poor agitation/spin cycle not working
The other shaft on the motor directly drives the pump. .
Jan 19, 2010 | Kenmore 24032\24036 Top Load Washer
Washer agitator seems to have quit working
First (and least expensive) thoughts are a broken motor coupler.
If the motor coupler is broken, or worn, the motor may not be able to send power to the transmission for agitating or spinning.
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but then nothing, put on spin cycle water empties. The agitator does nothing
the agitator is not on properly due to worn parts under it. remove the top cap, then use needlenose to remove the cap underneath it. lift up from very bottom of agitator. look for worn areas
Oct 07, 2009 | General Electric WHDSR209DWW Top Load...
Will not agitate or spin
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The top load, direct drive, neutral drain Whirlpool / Kenmore washers use a "Motor Coupler" between the transmission and motor.
When the motor goes into drain / spin mode, it reverses and drives the pump to drain the washer.
If the motor coupler is damaged / broken, the motor cannot get power to the transmission to agitate or spin.
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes.
Oct 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
