Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
How do i connect my ps3 to he internet. i dont know my ip code or wpa key
  • 1,272 Answers
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase(or network key).
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless PS3 to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Hope this allows you to resolve the issue.
Posted on Feb 04, 2010
What is a wap/key for the playstation 3
The WPA key (WEP or WPA-PAK are the options you get when setting up) is a method of securing wireless networks. The key in simple term means the password. This setting is not dependent on your PS3 but rather your WIRELESS ROUTER. If you do not use a wireless router then this setting does not apply to you.
You will need to log into your router settings. Using a PC, connect directly to the router and enter the routers IP address in a internet browser. (I type in http://192.168.1.1/ in the address bar of my browser on my pc to connect to my Linksys router.) LAN-IP address is normally set to a default, private number. Linksys routers (which is what i use at home) for example use 192.168.1.1 for their internal IP address. D-link and Netgear routers typically use 192.168.0.1 some US Robotics use 192.168.123.254 and so on. But you should be able to find what your router ip address is by going to their website or looking in your users manual.
i'm able to find my WAP key under the "router access" in the sub menu of "administration tab" its all ******** out like any other protected fields but i know what mine is and is able to change it there.
In the security settings there should be a WPA key setting. If this is blank then your wireless internet is unprotected. If this is set, then you will need to enter the corresponding key into your PS3 to obtain access to the network.
if you know who set up your wireless network for your home you can ask them for the WEP or WPA key. in simple term that is just a password that they use to set up your WEP or WPA
Sep 07, 2011 | Sony PlayStation® 3 (80GB) Console
My ps3 is saying my WPA key I entered is incorrect and is saying that obtaining my IP address failed and I just used my WPA key to get the internet on my computer and laptop, How do I get online working...
DO a power cycle on your router and try it after that.
Unplug the power supply on the back of your router wait 60 seconds and plug it back in. Wait 30 seconds then try to connect from your PS3
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
Need wpa key to set up internet with my ps3 but dont know wat that is?
WPA is a Wireless Internet Authentication technology. It is setup through your home wireless router. If you have home wireless internet, you should know your WPA or WEP key. However, you dont have Wireless, you might just want to run a network cable from your router to the Playstation.
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
I have connected my PS3 to the internet wirelessly before but I have recently moved into a new home. I consistently get the 8013013d Error code when trying to connect to the internet... But my room mate...
Hello :D
8013013D "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key PS3 can't handle WPA2 only WPA or none
May 21, 2010 | Sony Playstation 3 (PS3) Console
I have scanned for my internet and connected to it by typing in my wpa key. but when it comes to connecting the connection my ip address fail. do i type in my ip address manually? if so, where can i find...
First, make sure that DHCP is enabled.
Second, Don't use the pass phrase use the key.
  • For example, if you setup WEP to use a pass phrase like ROSEBUD, use the generated key code under it which would look something like AA34578E9...
Mar 08, 2010 | Sony Playstation 3 (PS3) Console
I have a 120 gb silm line ps3 console but a dont no how to hook it up to the internet
If you have a router in place connect the ps3 to it via ethernet cable. If the router is wireless with a WEP or WPA encryption code access the routers login page and get this code. Once you have the cable connected or the code turn on the ps3.
1:>On the ps3 dashboard go to (settings) then scroll down to and select (internet connection) select enable.
2:>Then go back to (settings), then scroll down to the bottom and select (network settings).
3:>Select (internet connection settings). This will bring up your internet setup page.
4:>Now select (easy) method.
5:>Choose wether wired or wireless. If wired skip to 8.
6:>Wireless will prompt you to select a wireless router (make sure you select your router) cause you may find others besides yours.
7:>After your router is selected it will prompt you to select either WEP or WPA select the one that the router uses and then enter the code.
8:>This will bring up your settings list most everything will be labled automatic. Press enter (X).
9:>Then select (test connection)
10:>After it is done back out.
11:>Now use your computer to go to plsystation.com and make yourself a PSN account with a username and password. After this is done.
12:>On the ps3 dashboard goto playstation network and select sign in, then enter your new PSN account name and password.
If you need anymore info do not hesitate to ask.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
Just bought second hand router belkin 54g trying to set up with ps3 it is asking 4 a wpa key and i dont know what to do can you help
the old owner of your router know the wpa code he/she inputed you must ask him wat is the wpa code since you are now the new owner you shold chnage also the old wpa code to new one....
Oct 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Ps3 error code 80711008 and wpa
OK for your WPA you can check the security key by accessing the router http://192.168.1.1 .. password is by default "admin" and username is blank...go to the "wireless" tab and check the ssid...under "wireless security" check the security key...if you have "wep" check the numbers in "key 1"....
now make sure that you connect to your own ssid and type the correct key...
and you are right , you need wlan to connect to the internet wirelessly...however , first make sure that you have internet working through the router..if not you will have to configure the router and for that you a computer connected to the router...
As for your IP address simple use this site http://www.ip-adress.com/ should be everything you need
May 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 Trouble due to WEP/WPA-PSK Key trouble
You can always press the reset button and wipe all settings out. You will have to re-enter passwords and encryption to protect your network.
Dec 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ps3 wirelesss conectin poblem
This is fairly easy.
1. Open network settings
2. Selected wireless and scan
3. When you see your router name click on that.
4. If you have a WEP security code you will need to enter that.
5. You should be finished!!
If you have any more questions, please comment here and I will come back and respond.
I hope this helps! Good luck to you!!
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
106 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
