Question about Sanyo Katana SCP-6600 Cellular Phone
Error c 26
Each time i tried to send a photo it said error c 26 please try again
  • 42 Answers
YOU WILL PROBABLY HAVE TO CALL YOUR ISP AND THEY WILL RUN YOU THROUGH THE STEPS..A BUSY SERVER DON'T STAY BUSY SO I WOULD SAY IT IS A TECHNICIAL ISSUE.
GOOD DAY
KZ
Posted on Feb 25, 2008
Camera error 26
I would be tempted to backup your photos, contacts and files.
Factory reset your phone and perform the software updates again.
Issue is likely a glitched update and will more than likely sort itself out if you do the above
Hope it helps
Jan 22, 2014 | Samsung Convoy Cell Phone
I use the settings recommended by my L358. However, when I set my camera to those settings in manual mode, my photos are dark. Why is this happening?
The fault is either with your camera/lens or with the meter itself. Try the meter with another camera, if the exposure error is still present then check that the custom compensation feature on your meter has not been set by mistake (page 26 of the user manual). If this doesn't cure the fault then try fitting a new CR123A battery. If the fault still remains then you can either compensate for the error by always using a longer shutter speed/wider aperture than recommended or you will need to send the meter for servicing.
Good luck, and please take a moment to rate my answer.
Aug 29, 2010 | Sekonic L-358 Flash Master Light Meter
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Gmail Error code # 008 OOps error while sending
Hi!
When ever iam trying to send any attachments to some id it is taking
time ,and at last iam getting a error message as
Oops.....the system was unable to perform your operation error code
008 please try again in few seceonds
pl help me how tp solve this problem this problem is comming since
morning
raju
Dec 24, 2009 | Google Gmail
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
E mailing photos
the mail id you typed may be wrong, pl. check the e. Mail address
May 26, 2008 | Dell Inspiron 1501 Notebook
Disc Error
the c:13:01 is the error code. I was researching this same thing on my camera. It 'magically' fixes itself after anywhere from 1 minute (turn off, count to 20 and turn back on)to 1 month later. This time, I lost photo-ops with my kids and their cousins. Apparently, this is a loose connector - see link- and you can fix it by 1) smacking your camera around a little (no joke, this knocks the connector back, for a little while or 2) sending it to Sony for repair (about $350) or 3) follow this guy's suggestions and fix yourself. I haven't lost any actual photos, except the first time when this happened. Since then, I've put the CD in the computer and I've been able to pull off the pics. Can't use the CD again though, even if it's not full. The camera must mark the CD somehow to avoid overlaying photos(?). Anyway, here's the link and good luck :) http://www.pechorin.com/m/2003/07/12/SONY_C1301_ERROR-202719-43.html
Oct 21, 2007 | Sony Mavica MVC-CD200 Digital Camera
Sanyo Katana SCP-6600 Cellular Phone Logo
272 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
