Question about Epson Aculaser C1100 Printer
New Printer - Remove Photocondctr Message
I have just installed the cartridges and the photoconductor for my new Epson Aculaser C1100 and I receive the message: Remove Photocondctr. What have I done wrong or what should I change?
  • Epson Master
  • 691 Answers
Did you removed all the packing materials from the PCU? Did you read all the instructions about setting up the machine and removing the packing pieces?
Have you removed the PCU as it suggested?
GO HERE FOR SETUP DATA SHEET
Posted on Feb 20, 2008
Epson Aculaser Photoconductor Unit problem !!!!
send it back and get a refund and try another supplier
Jan 30, 2012 | Epson Aculaser C1100 Printer
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
Photoconductor trouble
You will need to get the photoconductor unit replaced.
You can get detailed information about the same from:
ftp://download.epson-europe.com/pub/download/205/epson20540eu.pdf
Sep 11, 2009 | Epson Aculaser C1100 Printer
Epson C1100 Photoconductor kill chip
You can buy a new chip , empty the waste toner and then keep printing. Its only if the message is "replace photocnductor " though..
http://www.tonerangel.us/instructions/default.aspx
Jan 07, 2009 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
Replace Photocondctr???
You can buy a new photoconductor unit from any basic somputer store (i.e. Staples, W.B. Mason, etc.). While on the website, search for Epson Photoconductor, and there should be at least one search result.
I will warn you, this will cost you upwards of $200+
May 30, 2008 | Epson Aculaser C1100 Printer
Solution to epson c1100 error message
Turn printer off and remove photoconductor unit, close covers and turn printer back on without photoconductor, error will appear that you need to install photoconductor, install photoconductor and wait til it calibrates, if same error appears photoconductor is a consumable part you will have to replace it then.
Pls dnt 4get to rate solution. TY
Mar 18, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
464 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
