Question about Acer Aspire™ T180 PC Desktop
NO PERMISSION TO EDIT OR VIEW As an administrator, I thought I have all the privileges to edit, view read, modify, execute and write any folder, but on certain folders I must first grant myself the permission (full control) which is a tiring process. I also have the following names, ''users, administrators, system and authenticated users'', do I need all of this groups, or can I delete some? This is so frustrating, please help
  • Acer Master
  • 12,061 Answers
You need to Take ownership of those files...
For Files:
takeown /f file_name /d y
icacls file_name /grant administrators:F
For Folders or Directories (will perform action recursively):
takeown /f directory_name /r /d y
icacls directory_name /grant administrators:F /t
Replace file_name or directory_name with actual file name or folder name, with path when applicable. The first command will take ownership of the file or folder specified, and the second command will grant full control permissions to administrators user group. Note that when using command for folders, to command will run recursively. To prevent the task been perform recursively, remove the “/r” and “/t” switch.
Above two commands have been scripted in Windows command shell batch script that easily perform the task of taking ownership and grant full control permissions to Administrators user group by typing simple command. Alternatively, users can add “Take Control Of” option to right click menu so that the next time you need to take control of a file with full control permissions, it’s just a one click task.
Posted on Feb 04, 2010
Testimonial: "very helpful"
I dont have permission to open my files
It sounds like you need to 'Take Ownership' of the files on your new computer - this is something you can do with a Hard drive formatted with the Windows / NTFS File system (You will need to be logged on with Administrator privileges on your new computer) - Connect your old hard drive to your new computer (using a USB interface / or directly via SATA / IDE) Open your 'My Computer' Folder using windows Explorer - Right Click the drive representing your old hard drive and choose Properties > Security > Advanced > Owner --- Click the Edit button and change the owner to the account you are currently logged on with -- then save and close the security properties dialog - The Next time you open the security properties dialog you should be able to change the level of access to "allow everything" - If this is applied to an entire Hard Drive and you choose to change the owner on all sub directories and items within them it may take several minutes or even longer with a large drive 500 GB / 1 TB etc...
Nov 24, 2013 | Western Digital WD Passport 250GB Portable...
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Iomega 1tb drive have files hidden
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
Window cannot access the specific device,path,file. dont have appropiate permission
Ok this happens when the user account don't have the permission to acces the folder, disk etc.
Verify that the account you are using have the permission to access it. Right click the object you are trying to access and choose properties, then security (I don't know your window versions but is very similar in all versions). Check if the user account show in the box and the type of permission. If is not in the list should be add. To add you need administrator account privileges. çlick edit and add the user and the type of permission to grant. gabytek_1.gif
May 23, 2011 | Samsung N13013B Netbook
Dear Sir/Madam, Having installed XP 5 years ago. I founded some of problem previously, such that, perform reinstall XP, meanwhile, I can't get back my data when reinstallation. And, I tried to change...
Please, try the following depending on the XP version you have:
For Windows XP Professional Edition, disable Simple file sharing:
Click Start, and then click My Computer. On the Tools menu, click Folder Options, and then click the View tab. In the Advanced Settings section, clear the Use simple file sharing (Recommended) check box. Click OK. Then, follow these steps:
  • Right-click the folder in question, and choose Properties.
  • Click the Security tab.
  • Click Add, and type in Administrators, click OK.
  • Select Administrators group that you've added now.
  • Put a checkmark near Full Control (Allow) in Permissions box.
  • Click OK.
For Windows XP Home Edition, you need to start Windows in Safe Mode in order to see the Security tab. Remaining steps are the same.
Once you add Administrators group and give them Full Control for the folder, theMake this Folder Private option is automatically disabled. Level 1 permissions are no longer in action.
Mar 21, 2011 | Microsoft Computers & Internet
I can not edit my account information.
Hi there, I would like to clarify If you are the administrator on the computer your trying to edit your account
If you are the administrator of the computer, and If your computer is part of a network at an organization such as a school, government agency, or a business, your organization's system administrator might have disabled or even removed certain settings by using Group Policy. Group Policy is a feature of Windows that lets system administrators manage users' access to Windows features. If you suspect that Group Policy is preventing you from changing a setting that you need to access, contact your system administrator.
OR
If your computer is not part of a network, a user with administrator privileges might have modified Group Policy on your computer to remove access to the settings. In this case, contact the users who are administrators on your computer to modify the settings you'd like to change.
Jun 21, 2010 | Microsoft Windows XP Professional SP2
Though i know i have done backup on acer aspire e571
Your computer operating system is corrupt. Or maybe there is virus on your system that has made it corrupt.
Do you have any anti virus on your system? I will recommend that you try Avira Anti-virus. After you have installed the anti virus, use it to scan your system thoroughly and see if problem will persist.
If problem persist, then you will have to run the recover manager on your system. The recovery manager will help you repair and put your windows back to order, that is, to its factory default state.
Before you carry out the system restore, make sure you backup all your important files.
To do the system restore, click start menu, click all programs, look out for "Back up and recovery manager, click it and follow instructions.
I wish you the best.
Dec 18, 2009 | Acer Aspire 4315 Notebook
I get the message Value cannot be null parameter name: path 1
  1. In Windows Explorer, locate the application folder or the virtual directory that contains the content (for example, D:\MyWebApplications\Users\Main\App1).
  2. Right-click the root folder (MyWebApplications in this case), and then click Properties.
  3. On the Security tab, click Add.
  4. Type ComputerName\ASPNET (for example, on a computer that is named Webdev, type Webdev\ASPNET), and then click OK. Add the impersonated accounts if impersonation is turned on.
  5. Grant the following permissions for the ASPNET account (and for the impersonated accounts if impersonation is turned on):
    • Read & Execute
    • List Folder Contents
    • Read
  6. Click OK to close the Properties dialog box and to save the changes.
If you have to grant more restrictive permissions to these folders, follow these steps after you complete step 4:
  1. Click Advanced to access special permissions or advanced settings.
  2. Click the Permissions tab, and then select the permission entry for the ASPNET (or other impersonated account).
  3. Click View/Edit.
  4. Make sure that you grant only the List Folder/Read Data permission.
Nov 21, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Privileges
you can use Active directory. if you don't have Active directory, right click on the selected folder, choose porperties and then security.
in general term: go to control panel>>users accounts, select the user and select the permission rights you wan them to have. if the user is not listed,
goto control panel>> administrative tools>>computer management>>Local users and groups>> select users and add new user. name and password. (default is user-rights).
then you can go back to user acounts and change their rights.
Adminstrator=Full rights to all folder and file, software installation and uninstall.
Power user= 80% rights to software installation and uninstall, rights to view files not change.
STD user= right to their own folder and files only.
Nov 17, 2008 | Microsoft Windows Server Standard 2003 for...
Acer Aspire™ T180 PC Desktop Logo
149 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
