Question about Miele 36 in. KM3474 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
I have the 5 burner stove top KM 3474 with a right super burner which shuts off after 30 seconds. The other 4 burners ignite and remain on w/o any problem.
I have tried the following w/o any success
1). Swap burner unit from the left working super burner.
2) Cleaned the thermocouple with fine steel wool.
3). Reseated the knob.
I suspect the issue is that the thermocouple unit is not sending the correct voltage to the igniter unit so the gas is automatically cut off.
Miele tech support charges $170 (+parts) to send a technician out. There also appears to be no one local willing to touch Miele stove tops.
Miele tech support emailed me a repair manual for the KM 342 which appears to be an older version. The bottom plate of my KM 3474 has a "KM 342" label so mechanically, at least, the service manual appears to apply.
Has anyone had any success repairing a Miele stove top and getting repair parts ?
  • mpchew Apr 04, 2011
    The issue turned out to be a bad thermocouple. The Miele customer support will send out parts but the onus is on you since there are no returns.
    I opted to a repair technician who used to be an official repairman and close to getting a Miele qualified (but non Miele employee) certification. Slight discount but still pricey. He ordered kit to replace all the thermocouples (additional $40 vs $80 for one) and took 1 hour to install them.
    Problem Solver:
  • 15 Answers
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Posted on Feb 27, 2010
  • 2 more comments
  • advwilly Dec 25, 2010
    Yes, your advise to firmly press the burner knob down did keep the flame going and with igniter off but as soon as I release the burner knob, the flame stopped. Does this mean that thermocouple is not defective because it shuts off the igniter. Does this mean that the particular burner valve is defective or less sensitive to the thermocouple and needs adjustment. How do we fix this
  • Paul Collins
    Paul Collins Dec 26, 2010
    Here's how it works - There's a magnetic bushing
  • Paul Collins
    Here's how it works. There's a magnetic bushing and coil insde the burner valve that holds the valve open once the signal from the thermocouple is recognized. Pressing down on the knob bypasses this bushing and allows the gas to flow for igniton. You may have a bad thermocouple or burner valve, but I would check to see if the body of the thermocouple is grounded to the hob - a spillover could cause a bad ground.
  • advwilly Jan 04, 2011
    The thermocouple is connected to the main board and also directly to the magnet (actuator) unit inside the gas valve. I opened the gas valve and checked the magnet (actuator) unit and noticed that the default position of the magnet actuator is closed. If I connect the the thermocouple directly to the magnet actuator bypassing the circuit board, the igniter will work but I won't get a flame since the magnet actuator shuts off the gas. It seems that the main board sends signal to the magnet actuator to open the gas during igniting and then the after 30 seconds, the thermocouple takes over to maintain signal to the magnet actuator. IS THIS TRUE???? My second question is how do we test the thermocouple and the magnet actuator? What if the magnet actuator does not allow slight fluctuation in thermocouple signals? Now, If the igniter shuts off after burner had a flame, the thermocouple should be OK right? Can I assume that it is the magnet actuator that is faulty? Appreciate your expertise and help...thanks
How about the reverse, the burner lights, the ignitor clicks off but starts attempting reignite again even though flame is on. Any probable solutions to this problem??
Posted on Apr 04, 2011
After using the stove top and all the valves are shut, the igniter continues to click. Not sure which particular one, but I presume the right front, which is the most common used on the stove and the last...
One of the switches that turn on the spark when the burner is turned on has became stuck so even when the burner is turned off it still thinks its turned on. It very well could be the one for teh right front burner or any of the other 3 switches.
Depending on your mechanical ability its not too hard to figure out which one it is. What ya need to do is remove the panel over the burner valves so ya can get to the switches which slip over the stem of the burner valves and remove them in the off position and use a meter set to measure continuity and check each of the 4 switches when in the off position and see which one has a circuit (continuity) when off..when you figure which one has continuity when off that will be the one that is causing the stove to spark when off. Be sure to check all 4 since more than 1 could be bad.
BEFORE ATTEMPTING TO DO THAT AND CHECK WHICH SWITCH IS BAD BE SURE TO DISCONNECT THE POWER TO THE STOVE
GENE
Sep 16, 2011 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
When I turn any burner on, the ignitors work fine but it takes a very long time for the burners to ignite. Problem is worse the longer the top has been turned off. Once gas gets to the ignitor, it lights...
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Jul 15, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Miele Gas hob KM326G 2 burners won't stop clicking
Hello Leighvz,
The rings around the burners should be cleaned periodically. Each one has a series of holes to let the gas come out and have to be set back perfectly or else you will continually have this problem. You can clean with regular dish soap an water and a sponge or rag.
Also, If you put a pot or pan on the burner and it is too large it will cut off oxygen to the burner causing your clicking. The clicking only occurs when the oxygen supply is not enough. Hope this helps
Sep 07, 2009 | Miele 35 in. KM326G Gas Cooktop
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Stove top in lock mode
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
Feb 18, 2009 | Dacor Millennia ETT304 Electric Cooktop
Elect Ign not sparking, but get gas, other appliance working.
I don't know, I did nothing, it just started working again??????
Jan 28, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Burners will not light or stay lit
lhs burner - problem is probably thermo-couple. this is a safety device which prevents gas escape if flame blows out. rhs burner - you do not say if it can be lit by a match. if so then it is a problem with the electrode or the wire to it chaffed thro. if can't be lit by a match, then a problem with the gas valve which is unusual not a diy fix unless you are experienced
Apr 11, 2007 | Miele 30 in. KM320G Gas Cooktop
Miele 36 in. KM3474 Gas Cooktop Logo
1,472 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
