Question about HP Deskjet 6980 InkJet Photo Printer
Re: Smudging Inkjet 6980 printer - everytime I print out on glossy paper there is always a smudge line that appears on the page at the top. How can this be fixed?
  • 1,019 Answers
Try Cleaning the printheads. you usually have a utilitie to do this in :- Printer preferences. Also try several Print test Pages. It appears that your getting a surge of ink, at the initial printing stage. use standard paper to do all tests with. 1:- it,s cheaper. 2:- it,ll help soak-up any surplus ink. whereas the glossy paper does,nt soak it up too well. If these solutions don,t help. check HPs site for fault diagnosing and repairing.
Hope this helps you in the right direction.
Posted on Feb 20, 2008
Canon PIXMA iP4200 not printing PGBK properly - only printing top 50% of PGBK grid on test page.
Man you did some awesome troubleshooting! I don't know, but it sounds like something is physically wrong with internal electronics. I'd call in the big dogs at Canon themselves.
Nov 17, 2016 | Canon PIXMA iP4200 InkJet Photo Printer
HP Photosmart Premium c309a series smudging wedding invitation envelopes badly. I can print the invitations and everything else just fine. Any suggestions? Thank you.
when you go to print your envelope and click the print command - a window will open with the name of your printer and a box that says properties. click on properties. Change the type of envelope stock to match what you are printing on in the next window. If you are using photo paper envelope with a glossy finish, make sure that is the print media you have set for your printer. If not, the ink will just keep smudging. it's very important to match the print stock (matte, glossy, premium ect).
Oct 09, 2011 | HP Photosmart Premium C309A All-In-One...
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
HP4-smudged copies of printed text are appearing lower on the page...Any ideas on the fix
Run a 1/2 test.
Put paper in the manual feed tray(tray 1).
print something. And watch the paper. As the paper gets
about 1/2 way into the printer, open the top cover, remove the toner.
Look down at the paper. If you don't see smudged text, the fuser is probably bad.
If you see the smudging, replace the toner.
Dec 02, 2010 | HP : HP4 Laserjet Printer
Dell 3100cn (color printer): color smudging
Smuding typically occurs when you print on a heavier paper without changing the settings. By changing the settings to a thick paper type, the page will be send through the printer more slowly. this will likely eliminate the smudging.
Sep 24, 2009 | Dell 3100cn Laser Printer
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
change the print cartridge for color if yhat doesn't fix it get a new print head. Bob
Mar 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Deskjet 6980 InkJet Photo Printer Logo
152 people viewed this question
Ben Johnson
