Question about Eclipse CD2000 CD Player
IS there a left and right audio input in the rear
I have a Eclipse CD200 and im wonder if there is a left and right audio input in the rear part of the head unit?
    President:
  • 547 Answers
No, the RCA jacks on the back of a CD2000 are line-out, not inputs.
Posted on Feb 04, 2010
Where is the amp and how do i check it in 98 cadillac
Radio Amplifier
Left hand rear of the passenger compartment, behind the rear seat back.
Check the connections , check power an ground .
Connector Part Information
12110088
24 Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
PPL
1952
RH Front Tweeter Output -
A2
LT GRN
1852
RH Front Tweeter Output +
A3
BLK
1856
LH Front Tweeter Output +
A4
YEL
1956
LH Front Tweeter Output -
A5
DK BLU/WHT
346
Rear Shelf Subwoofer Coil 1 Output +
A6
LT GRN/BLK
1794
Rear Shelf Subwoofer Coil 1 Output -
A7
YEL
1860
Center I/P Midrange Output +
A8
LT BLU
1960
Center I/P Midrange Output -
A9
DK GRN
1795
Rear Shelf Subwoofer Coil 2 Output +
A10
LT BLU/BLK
315
Rear Shelf Subwoofer Coil 2 Output -
A11-A12
Not Used
B1
DK GRN/WHT
368
Right CD Changer Input
B2
BLK/WHT
372
CD Changer Common
B3
BRN/WHT
367
Left CD Changer Input
B4
LT GRN
1948
Right Audio Input -
B5
LT GRN/BLK
512
Right Audio Input +
B6
DK GRN
1947
Left Audio Input -
B7
TAN
511
Left Audio Input +
B8
DK BLU/WHT
653
Chime Input/Return
B9
PPL/WHT
652
Chime Input +
B10
Not Used
B11
PPL
1807
Class 2 Serial Data Line
B12
PPL
1807
Radio Amplifier (UX8) C3
showgif.do?image=35456
12064749
2 Way F Metri-Pack 480 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
651
Ground
B
RED
1242
Battery Positive Voltage (B+)
Check
Mar 22, 2016 | 1998 Cadillac Seville
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
Trying to hook up my daughters dvd and tv. I've got one set of cables with yellow red and white connections,where do they go?
Red is for Left Audio Output, to TV Left Audio Input
White is for Right Audio Output, to TV Right Audio Input
Yellow is for Video Output to TV Video Input
You should see the same color coded RCA jacks on the rear of your TV unit. Just match the inputs to the correct device ie: Video 1, Video 2, etc
Aug 09, 2011 | Televison & Video
Hey ive just bought Logitech Z506 surround sound speakers and im just wondering how do you connect it to your T.v ive tried and the rear left works, rear right works, the front left doesn't work and the...
you will probably have to buy some 2 to 1 input plug adapters and set them up
i cant see your television so im not sure of its speaker set up
hope this will help you
Mar 07, 2011 | Logitech X-530 Computer Speakers
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
Jul 05, 2010 | 2001 Mitsubishi Eclipse Spyder
Need wiring diagram for 5504 eclipse head unit
The factory plug should be whitish-clear and have the following wires Yellow=power input red=switched power input (accessory) black=ground orange or orange/white=illumination blu=power antenna trigger blu/wht=amp turn on the speakers will be pairs of colors, the one with the black stripe is negative: whites=left front greys=right front violets=right rear greens=left rears
May 19, 2010 | Car Audio & Video
Trying to re install stereo and need the wiring colors and diagram
Sony, Alpine, Pioneer (1999 and up), Eclipse, Kenwood, JVC, etc up_arrow.gif P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Jul 08, 2009 | Pioneer KEH-P2800 Cassette Player
Need wiring diagram for Kenwood KDC MP 228
Jul 08, 2009 | Kenwood KDC-MP228 CD Player
Eclipse CD2000 CD Player Logo
98 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
