Question about RTO Buoyancy Compensator Scuba Bcd Joe Loves This One
Co2 valve unglued - RTO Buoyancy Compensator Scuba Bcd Joe Loves This One
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question.
Posted on Aug 10, 2010
How should I install a new co2 canister without losing air pressure?
Unless it has a shut off valve, u can not replace it without loosing co2
Jun 02, 2014 | Crosman (4032)
Hi sir , i have problem in my car code p0410 and i checked co2 its 14.8 and high what is the part need to check or change
code p0410 refers to secondary air injection(AIR) system---malfunction====causes --wiring---AIR valve---AIR solenoid---ECM
check /replace the air solenoid and/or valve.
Jan 01, 2014 | 2005 Peugeot 407 2.2
Daisy 008 pistol co2 clynder leak
Hi Romi das...
Check out this video, I am sure it will help explain how to repair the 008 Daisy you have.
Please rate me
Bud
http://www.youtube.com/watch?v=li_S25ChYTA
You can contact Daisy for parts at:
Daisy Outdoor Products
P.O. Box 220
Rogers, Arkansas
72757-0220
FREE (800) 643-3458 end_of_the_skype_hi
info@daisy.com
Oct 13, 2012 | Daisy Powerline 008 - 0.177 Caliber
98 Custom Act Paintball Gun: i have just brought a 98 tippmann custom and it ha...
Basically speaking, air is air. Now it's the pressure that's the concern. co2 bottles use a regular valve that has a pin in it and opens to allow the gas through. High Pressure Air - HPA is the same concept but since the pressure with co2 is built up by expanding gas, HPA has to do it with pressure only. So the tank is pressurized a LOT higher than co2, but there's a regulator on the tank valve to bring the working pressure into the marker to the proper level.
So yes, you can use "air", but you need to make sure it has the right output for your marker. (i.e. not a low pressure HPA valve.).
You'll have the same problem though, getting someone to fill the bottle. Check with your local airsmith and paintball fields and stores. If they have co2 they would have HPA, but some do only deal with HPA since it's "easier" in some cases.
You may have to check around. Sometimes hardware stores have a small section in back, or you can check with the paintball places around to see if anyone in your area is equipped. Some teams have their own tanks, especially if there's not a place to get fills locally.
There's also online communities like Brigade and various paintball sites where you can check around for other players. Someone may have a co2 fill tank, a scuba tank for HPA, or a group that gets tanks together to make a run and get them filled somewhere.
Play hard, play safe, play with honor!
8^)
May 18, 2010 | Tippmann 98 Custom Act Paintball Gun
Won't hold co2 at all when cartridge is installed, all co2 comes out instantly
It sounds like the check valve is stuck open. Also, the seals may have either become twisted or torn. An internal inspection (also known as a tear down) is in order. Check with the manufacturer's website for instructions and/or assistance.
Aug 15, 2009 | Crosman (4032)
Beer dispenser
Shut of the CO2 tank, then hit the pressure release valve on the side of the beer tap. Make sure there is a grey check valve in the tap where the red hose (co2) is connected. Also make sure the white ball in the tap where the white hose (beer line) is not stuck. You can remove this, it isnt really necessary. Once all checks out, open the tank and readjust the co2 regulator. The reading should not be more than 12 PSI. Everything should work just fine after this. Make sure the glass is as close to the faucet as possible (slanted is better) when dispensing beer. Hope this help :)
Jan 21, 2008 | Haier (HBF05EAVS) Beverage Dispenser
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
RTO Buoyancy Compensator Scuba Bcd Joe Loves This One Logo
372 people viewed this question
Top RTO Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a RTO Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
