To create a password for folders
How we can create a password for folders?
  • 97 Answers
Try folder lock
Here is the link: http://www.newsoftwares.net/folderlock/
This one is just free version if you want a full version try to look in this link: www.torrentportal.com
Posted on Feb 20, 2008
Tip
How to Make Invisible Password Protected Folder Submitted by Srikanth on...
How to Make Invisible Password Protected Folder2761870.jpg Submitted by Srikanth on Thursday, 10 December 200930 Comments Do you want to password protect your folder? Do you want to make it invisible so that it remains unnoticed by the normal users? Well here is a way to do that. In this post I will show you how to make a password protected folder in Windows without using any additional software. Here is is step by step procedure to create a password protected folder.
How to create a Password Protected Folder
Step-1: Create a new folder (Right-click -> New -> Folder) and give it any name of your choice. For instance I name it as ABC.
Step-2: Now in this folder place all the important files, documents or any folders that you want to password protect.
Step-3: Now Right-click on this folder (ABC) and select the option Send To -> Compressed (zipped) Folder.
Step-4: Now a new compressed zipped folder gets created next this folder (ABC) with the same name.
Step-5: Double-click on this compressed zipped folder and you should see your original folder (ABC) here.
Step-6: Now goto the File menu and select the option Add a password.
ie: File -> Add a password
Now a small window will pop up and here you can set your desired password. Once the password is set, the folder will ask for the password every time it is opened. Thus you have now created the password protected folder.
How to make it Invisible
Step-1: Now Right-click on this password protected folder and select Properties.
Step-2: At the bottom select the option Hidden and press OK. Now your folder gets invisible (hidden).
Step-3: In order to unhide this folder go to My Computer – >Tools -> Folder options. Switch to View tab, scroll down and under Hidden files and folders you’ll see the following two options
  • Do not show hidden files and folders
  • Show hidden files and folders
Now select the second option and press OK. Now the invisible folder becomes visible in it’s location. To access it you need the password. To make it invisible again repeat step -1 through step-3 and select the first option and click OK. Now the folder becomes invisible once again.
I hope you like this post. Pass your comments!! Cheers
on Mar 30, 2010 | Computers & Internet
Tip
Create a password protected folder without any special software
In an earlier post I had written about how to create an invisible folder. That’s a method to create a merely invisible folder with no real protection.
Now, here we will see how to create a folder that will not just be invisible, but also require a password to reveal it and open it. The best part is that you don’t need any special software to do this. Just plain old Notepad is all that you need.
Here is the code that you need:
cls
@ECHO OFF
title Folder Personal
if EXIST “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” goto UNLOCK
if NOT EXIST Personal goto MDLOCKER
:CONFIRM
echo Are you sure u want to Lock the folder(Y/N)
set/p “cho=>”
if %cho%==Y goto LOCK
if %cho%==y goto LOCK
if %cho%==n goto END
if %cho%==N goto END
echo Invalid choice.
goto CONFIRM
:LOCK
ren Personal “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
attrib +h +s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
echo Folder locked
goto End
:UNLOCK
echo Enter password to Unlock folder
set/p “pass=>”
if NOT %pass%==pwd123 HERE goto FAIL
attrib -h -s “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}”
ren “Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}” Personal
echo Folder Unlocked successfully
goto End
:FAIL
echo Invalid password
goto end
:MDLOCKER
md Personal
echo Personal created successfully
goto End
:End
Now here is what you need to do:
Just copy the above code and paste it into Notepad. Save it by giving it any name you choose. Assuming, the file is called secret.txt, change the extension to ‘.bat‘ so that the new name becomes secret.bat. What you get is a batch file. You could actually save one step by saving the file in Notepad directly as secret.bat by enclosing the file name like this: “secret.bat” . This batch file is the one that you need. You can edit this batch file to change the folder name and the password. To change the name of the folder that is created, change the ‘Personal’ (in bold in the above code) to any another name you choose. Likewise change the ‘pwd123′ (in red in the code) to anything else.
Now let’s see how to use it. Place the file in the location where you would like to create your protected folder. Run the batch file by double clicking on it. This will create a folder named Personal in the same location as the batch file. You can now open this folder and place any files in it. Once you are finished, run the batch file again. You will be asked whether you want to lock the folder. Entry ‘Y’ (for Yes) and hit Enter. The folder becomes invisible. To retrieve the folder, run the batch file again. You will be prompted to enter the password. Enter the password, hit enter and voila! the folder appears.
Important: The batch file acts like a key to open the locked folder. So once you have created and locked a folder, do not keep the batch file in the same location since anybody can open the batch file and view your password. So I would suggest that you keep the batch file in a separate and safe place or better still keep it on your pen drive or flash drive. That way when you want to open the folder just copy the batch file to the location where you have your protected folder and run it.
Do remember that the above method is not intended to act as a substitute for the numerous free and commercial softwares that are specifically designed to provide security and encryption to your data.
Update: I got comments saying the code does not work. Of course I did check it before posting it here. But I have identified the problem. The problem is with the straight double quotes used in the code in this post. Once you copy the code you would also need to change each of the double quotes with your keyboard double quotes. That might seem a lot of work for some. So I thought it would be easier to give away the batch file itself. You can download the file here. (Use right-click and ‘Save Target as’ or ‘Save Link as’).
on Mar 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
I want to put a password on my flash drive
Plug your Maxwell USB flash drive into your computer.
Click on the "My Computer" icon at the top of your computer screen.
Double click on the Maxwell USB icon.
Right click in a blank space in the middle of the window to pull up a small menu.
Select the "New Folder" option from the menu to create a new folder on your Kingston USB drive.
Drag all of the files that you want to protect into the new folder you created.
Right click on the folder that you created and select the "Properties" option from the menu.
Go to the "Sharing" tab and click on it.
Scroll down to the "Make This Folder Private" box and check it. Click the "OK" button and wait for the window to close.
Use your Windows log-in password to open the file.
There are also encrypt/password protect programs downloadable on the internet some are freeware some are pay programs
http://download.cnet.com/truecrypt/3000-2092_4-10527243.html
True Crypt Free
hope this helps
Nov 12, 2012 | Maxell 4 GB USB 360 USB 304 - 503201 Hard...
I creted a folder and put private things in the folder and i want to try and crete a password to the folder so that im the only 1 that can get in the folder
Hey, I'm going to assume you are running Windows, so let me provide an easier solution rather than creating a password for a folder.
Instead, you can create a ZIP file which contains all the "private things" you want to store, then put a password on the zip file.
- Download WinZIP: http://www.winzip.com/downwz.htm
- Install it by double-clicking on the file you downloaded
- Next, select all the private things you want to protect, right click on them and select "Add to Winzip".
- On the dialogue that will appear, you can add a password to your zip file, and then hit create.
That's it!
The file you created is called a "zip" file, and it contains all the private files you want to store. You can drag any new file you want to add on your zip file, and it will be added inside it (after you type your password). You can also take your zip file with you wherever you want!
It's a much easier solution that creating a password for a folder.
Alternatives:
7zip can also do this, and it's completely free, but a bit harder to use: http://www.7-zip.org/download.html
May 12, 2011 | Computers & Internet
Trouble mapping Savin to network folder on computer
you will need to have the folder shared on the desktop. you will need user name and password. go to user tools. system settings. administrator. address book. create new user. in new user program, go to folder. enter computer name. browse network. you then enter user name and password for pc. should be done
Oct 21, 2009 | Savin Office Equipment & Supplies
Password on shared documents on a workgroup
Password Protect Folders in XP
To password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
If you have a log in password for your account, this can be used to protect folders from other users. If not, you need to creat one. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
Right-click the folder that you want to make private and choose "Properties" (or Alt+Double-click). Go to the "Sharing" tab and check the "Make this folder private" box.
Click Apply . If you do not have a password on your account, a box will pop up asking if you want to assign a password. This must be done if you want to make the folder private, so click Yes . You will need to use your password to log on to your computer from then on.
Type in a password then confirm it. Click the "Create Password" button then close the Password window.
Click OK in the Properties dialog box.
Now anyone else logged on to your computer can't access that file without knowing your password.
Dec 02, 2008 | Microsoft Windows XP Professional
Password problem
Attach your HD with another PC, select Folder properties "show hidden files n folders" and search/ find your desired folder. Right cllick it and change its properties so it will be no more hidden. Reinstall you HD in original PC and have fun.
Jul 29, 2008 | Microsoft Windows XP Professional With...
PASSWORD FOR FOLDERS
windows xp dont have any inbuilt folder password option.you have to search for software like folder guard to give password
Apr 03, 2008 | Microsoft Windows XP Professional
Create password to a folder
First, make sure you have a password when you login to your computer.
Right click the folder you want to protect.
Click "Properties"
Click "Sharing" tab
Place a check mark on the box that says "Make this folder private"
Click "Apply"
If you don't have a password assigned to your account, there will be a popup box that will ask you to assign one. It must be done if you want to make the "Folder" private, Click "Yes". You will then use the password when you logon to your computer.
To confirm it, Click the "Create Password" button and close the password window. Click OK.
The password will then be asked eveytime somebody tries to access your private folder.
Nov 27, 2007 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Alun Cox
David Payne
David Payne
