Question about Honeywell Programmable Thermostat Heater
Temperature is not reaching set temperature. Furnace flames twice then stops, then fan kicks in and runs for 5 mins then stops. Then flames twice. Then stops working all together. The flame never burns when the fan is on. I have to go and flip the breaker and the cycle starts again. Please help because my house is freezing. Thanks.
  • 118 Answers
Tara,
If flames go on and then go right out it is usually a flame sensor problem. These are usually found on newer furnaces with electronic ignition systems. It will be located in the flames of the burner farthest away from the ignitor. If you see an orange glow before the flames light then thats it! If ignitor is on the right side then flame sensor is at the opposite end. It is a round steel probe with a white ceramic top and a wire running to it that sits in the flame and is a little bigger round than a coat hanger. Shut off power, wait to make sure it is cool to the touch, using a piece of steel wool( or sandpaper if none available) give it several good strokes to clean it. You may have to remove it from the top by removing the screw and pulling it out. I usually can clean them without removing them but I have small hands! Turn power back on and it WILL run if that was the problem!!!!!!
Posted on Feb 04, 2010
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Furnace kicks on and heats up for 5 min. then will shut down - no flame - main blower will run for a few min and then the whole cycle will start again. flame sensor checked ok with meter at approx 5.0
What is your temperature rise during the 5 minutes it does run? Could be overheating and kicking out on limit switch. Watch the diagnostic light for a code. (3 blinks means this, 4 blinks means that etc.)
Jan 09, 2014 | Amana Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
The flame stops burning when the blower kicks on but the furnace is still calling for heat
If this is a standard house heating system, could the blower control switch be set too high and too close to the high temperature setting. If the temperature reached the high limit, the flame would be cut off.
Gary
Feb 10, 2011 | Coleman Heating & Cooling
My heater blows cold air why? I have a REAB 1010s need manual
Check your thermostat to see what your fan switch is set on. There should be two settings - auto and on. If it is set on auto, the fan only comes on when furnace runs. If the switch is set on on, the fan on your furnace is running all the time. Which means when temperature in the house reach what you have set on your thermostat, the furnace kicks off, but the fan keeps running and blows cool air. Some people run their fan all the time, especially if they have allergies, because that's a good way to clean the air.
Jan 02, 2011 | Heating & Cooling
My furnace kicks on, runs a little while, kicks off, then kicks on again until desired temperature is reached
it could be the thermostat on the wall not working or the fan control is not working as it should also check to see if air filter is blocked
Oct 24, 2010 | Dayton Gas Furnace Heater
The blower fan comes on several minutes before the
Bad fan switch. It may also be called a fan limit switch. If your furnace is less than 5 years old, the switch is part of the circuit board and you will need to replace the board.
Jan 11, 2010 | Heating & Cooling
The furnace won't stop at the programmed temperature set ponts
this is called a swing tempature it is desined to improve the eficincey of the frnace because it take less energy to run an hour in a three hours then 3 bursts of 25 min in a three hour period
HOWEVER if you do not like this you can usualy set the swing temp
Jan 16, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
844 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
