Question about RCA E13309 13-Inch Diagonal XL-100¿ Color Television Television
Part of the picture is cut off on the top of the tv. how do i fix this problem on my citizen jctv3245xb tv? this happens for sports programs mainly or any thing with a streaming type on the bottom of the tv.
4 Suggested Answers
  • 317 Answers
SOURCE: picture cut off
unplug overnite.
Posted on Aug 03, 2008
  • 8 Answers
SOURCE: picture
I HAVE A SANYO, ON MY REMOTE CONTROL IS A BUTTON "PIX SHAPE" this will change the sides and top/bottom. I have 4 settings. OR you might check you owners manuel as to where this button is. Possibly under menu. My Dads TV is a little different from mine. so your button might not be where mine is.
Posted on Nov 23, 2008
SOURCE: RCA HDTV D52W23- words in 3D - picture at top and bottom black
are you still having this prob? i am having a similar prob with the same brand of tv. if you had yours fixed please help me with mine.
i think it is the convergence ic. i need three ic but the distributer will nit sell no less than ten of them. if you or anyone need any of those ic i could let you some for the same unit price i bought them. posted 09/02/2009
Posted on Sep 02, 2009
Sanyo tv cuts on then right back off
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_2_17_54_pm.jpgbad caps that are puffed up on top..
Apr 10, 2012 | Sanyo Televison & Video
I just purchased a Samsung UN46C6300 LED TV. The picture is cut off on top and bottom no matter which picture option is selected. Is there something I can do to fix this?
I had the same problem for a few days with my samsung tv which is the main reason why I am posting this solution though I am sure you, dvought, have found a solution by now. Hopefully. for all you other folks out there who have just made a desperate search on the internet like myself to solve this problem and have a cable box/satellite connect, please check your picture size settings for the cable box and change it from zoom back to normal. once i did this i was able to see all the writing and sports scores that were previously not showing before because they were cut off.
Dec 23, 2010 | Samsung UN46C6300 TV
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
LG TV MODEL 442L0520 SERIAL 005RMKUA3341 PICTURE IS TOO BIG FOR THE SCREEN,K TOP AND SIDES CUT OFF. WHEN WATCHING SPORTING EVENTS, SCORES CANNOT BE SEEN.
You need to go into the TV menu and change the settings for the display! Press the Menu button and adjust the Picture! It's probably set to automatic and not reading them correctly.
Sep 28, 2010 | LG Televison & Video
I too have the problem where the top and bottom of the picture is cut off on the TV screen. No formatting of any kind fixes it. What is the answer?
Some of the wide screen programs will leave blank strips top and bottom of the screen, you can fill the screen if your TV or the remote has picture size buttons where you can select "movie" mode or "movie zoom" modes. try stepping through picture size buttons. Some times it is marked as "wide" on your remote.
Jan 03, 2010 | Envision L32W761 32 in. LCD TV
Samsung 650 LCD picture is cut off top and bottom
select the correct tv format, check your manual
Jan 01, 2010 | Samsung LN46A550 LCD TV
The top of my picture is cut off.
Change the video output to wide screen
Oct 15, 2009 | Sony Televison & Video
My picture looks funny on all four sides.
its due to the faulty convergence. the stk convergence ic on the main board which controls the picture alignment is faulty and needs to be replaced to solve this problem.any tv technician will do it for you at a very negligible cost. nothing to worry.thanks.
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
Picture size
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 05, 2008 | Toshiba 50H82 50" Rear Projection...
What are all the remote codes for the citizen tv, is there a web sight
001 / 004 / 008 / 009 / 042 / 053 / 058 / 105 / 109 / 177
These are the codes for citizen models, try one till you find the one for your citizen TV.
Dec 02, 2007 | Televison & Video
Televison & Video Logo
65 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
