Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do I remove the rotating knob on a Whirlpool washing machine
I have removed the instrument panel aand I need to remove the knob on the front. How?
    Habit-Forming:
  • 84 Answers
Theres a black pin on the back of the timer pull that out and the knob should release,put it back to snap the knob back on
Posted on Feb 06, 2010
Where is my pump filter whirlpool duet front load washer
When your Whirlpool washing machine won't drain, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
1 - Unplug the washing machine. Lift the front end and place two-by-four blocks under each foot to keep the front elevated. 2 - Unscrew the three screws at the bottom of the panel, using a Phillips screwdriver. Remove the panel. The drain pump assembly is directly in front of you, in the middle of the machine. 3 - Unscrew the knob on the drain pump by turning it counterclockwise. Hold a bucket in front of the pump while you remove the knob to catch the water. There may be as much as 2 or 3 gallons. 4 - Turn the knob over. The filter is on the back. Check the filter and remove any debris or lint. Replace the drain filter onto the pump. Screw on the access cover. Take the machine off the blocks and plug it in.
Dec 21, 2016 | Whirlpool Washing Machines
E1 f9 code front load duet washer how do we fix it
When your Whirlpool washing machine won't drain, or is displaying the E1 F9 error, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
Dec 21, 2016 | Washing Machines
E1 F9 code front load washer whirlpool duet
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
How to remove dash panel to replace climate control panel
  1. Remove the instrument panel accessory trim plate around the control panel by prying gently and then pulling it straight out.
  2. Remove the control panel mounting screws.
  3. Pull the control panel straight out from the instrument panel.
  4. Disconnect the electrical connectors.
  5. Installation is the reverse order of removal.
  6. After installation, the actuators must be calibrated. For additional information, refer to the following section, -Actuator Calibration.-
  8. Fig. Remove the screw and pull the control panel straight out of the instrument panel.
To calibrate the system:
  1. Place the ignition switch to the OFF position.
  2. Install the HVAC control module.
  3. Connect all previously disconnected components.
  4. Start the vehicle.
  5. Wait 40 seconds for the HVAC control module to self-calibrate.
  6. Verify that no DTCs have set as current DTCs.
  7. Place the ignition switch to the OFF position.
  8. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  9. Rotate the Mode knob fully counterclockwise.
  10. Rotate the Mode knob fully clockwise.
  11. Rotate the Mode knob fully counterclockwise.
  12. Release the AC button.
  13. Wait 40 seconds for the HVAC control module to self-calibrate.
  14. Start the vehicle.
Sep 14, 2011 | 2001 Oldsmobile Silhouette
How do you remove the filter???? it doesnt say in the instructions
The drain filter in Whirlpool front load washers is located at bottom front inside of the machine. Remove the screws securing the bottom front panel to the cabinet then pull the panel down and off. You can prop up the bottom front edge of the machine with a block of wood or cushion the rear top edge and lean it against the wall for easy access and removal of the screws.
Once the panel is off, you'll find a knob which the filter itself. Turn the knob counterclockwise to remove and clean the filter. You may need to lay a towel under the filter to catch residual water before removing it. Manually drain the water, by gravity, from the tub if significant amount of water is still present by placing the end of the drain hose as low as possible into a basin or bucket.
Jun 18, 2011 | Whirlpool Washing Machines
Whirpool front loader washing machine,. my control panel is stuck on "control locked" position. How do I unlock my washing machine?
Dont know the model but try and unplug for a awhile aand see if that does the trick if not call whirlpool or check out thier site
Feb 15, 2011 | Whirlpool Washing Machines
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 13, 2010 | Whirlpool Washing Machines
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
171 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
