Question about Tablets & eReaders
Laptop sir, my laptop caught some problem.yesterday i removed the battery and then place it proprerly.after that i can't open my laptop i.e; my laptop cannot switch on.i tried continuesly,but today suddenly i was switch on.so i checked once more,but unfortunately i can't switch on Sir,So i requested you to give me the correct solution.this is my humble request
  • fishyouu Aug 09, 2008
    yes gosh. my hp compaq presario v3000 is not even one year old and it's having problems! how lousy!!
    i get freakin irritated everytime i need to use the laptop urgently yet it can't be switched on.
Junk
Posted on Jul 31, 2008
    Novelist:
  • 142 Answers
If it was working fine before then are many reasons why this could happen
1. Battery is old and is dead
2. Battery not plugged in properly
3. Carbon might have appeared at the ports where the charge passes thru in the laptop
Solution: open the cover where u put the battery, The ports where the battery goes in , try to touch the metal area with any other metal so that if there is any carbon it passes thru to the other metal... and the ports become free
4. Try to do a flee power release
MAke sure battery is fully charged.
Take out the battery from laptop
when the battery is out , press the powe button on laptop for 30 sec and then put the battery in ur lapyop and try to trun it on by pressing the power button firmly.
IT shud work
OR
Try different batteries ( u can borrow )
if it still does not work
They contact laptop vendor , the ports where the power from battery goes in to ur system are faulty
Take it to an authorized service center.
Posted on Feb 20, 2008
I brought my irulu tablet yesterday downloaded some apps and it started to freeze when I switch it off and back on it takes long to load and also resets itself
I had similar problem with HP tablet which was not answered by them. Later I found it has got DEEP DISCHARGE problem.ie. it is allowing the battery to go to deepdischarge stage due to circuit problem. The circuit should make itself dead and prevent the battery to go to that level. Virtually the battery enters into COMA stage ! Keep it in switch off stage for 48 hours with charging on - so that the battery comes to life again and charges itself. Later my tablet is OK.
Jul 30, 2016 | Tablets & eReaders
The back popped open on my ematic and the silver pouch inside is swollen How do I fix it
Whilst I am not familiar with the brand of tablet you have, please be warned that it is in a dangerous condition. The "silver pouch" you mention is the Lithium battery that powers the tablet, and the fact that it is swollen means it is faulty and could rupture (split open) anytime. The danger here is that the Lithium inside the battery will ignite in a very hot flame if it comes into contact with air, which it obviously will if the battery splits open. Do not store the tablet inside your home until the battery has been replaced. My advice would be to unplug and remove the battery if it is plugged into the mainboard of the tablet, place it inside a fire resistant container, and take it to your nearest battery disposal location. Then you can most probably source a replacement battery either on eBay or from the store where you purchased the tablet. If the battery is soldered in place and you do not have the tools or expertise to remove it, then I'd advise that you call a local PC or cellphone repair company and see if they are willing to remove and replace the battery for you. If they are, take the tablet to them (in a metal bucket or similar, just in case the battery fails). The swelling of the battery's casing is the result of gasses being generated inside the battery, and indicate that it may be in a very dangerous condition, so I stress again, it is a potential fire hazard and should not be kept it inside a building unless it's in a fire retardant location.
Jan 02, 2015 | Tablets & eReaders
Sim card in a panasonic cf-h2
To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
Mar 22, 2013 | Panasonic Toughbook CF-H2ASFAZ1M 10.1" LED...
Why so long when i'm charging my lenovo a1-07 ideapad
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Hope this helps.
Dec 29, 2012 | Lenovo IdeaPad A1 Tablet with 16GB Memory...
How to remove battery from zeepad 7.0 tablet
Hi open a zeepad is very easy, you need apply some pressure over the case and the screen. I recently open my sons tablets. regards.
Oct 29, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
CX200X worked fine yesterday, now I am unable to turn the power on to the laptop. I have power through the adapter to the connection to the computer. I have a full battery charge light indicator. When I...
make sure the power lock button on the lower righthand side is in the UP position.
it locks the computer into the OFF state if it is switched DOWN after powering down.
Jun 17, 2009 | Gateway CX200X Tablet PC
Toshiba Portege 500 Laptop
need a toshiba mother board for m40x250
Aug 04, 2008 | Toshiba Portege M400-S5032X Tablet PC
ASUS F3S startup problems...
Have you tried doing a system recovery using the "hot" keys for the machine. Contact ASUS support for the instructions.
Apr 11, 2017 | ASUS R1E-B1 Tablet PC
Setup password
i think the computer is asking for bios pc if it is bios then you have to open the case and remove the bios battery for five sec.before this you have to remove the power plug.after five sec. just resit the battery and put the power plug back and switch it on.
plz post your findings
Apr 23, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Tablets & eReaders Logo
289 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
