Question about HP Pavilion 753n (P9852AR#ABA) PC Desktop
I have tried to add PCI wireless cards, and a dual VGA card to my 753n. Each time I install the card the computer will power up, but not even get to the BIOS screen. I have removed and reinstalled the CMOS battery, tried different cards, all with the same problem. Once they are removed, the computer boots fine. It has a PCI FireWire card that was factory installed, adn I can move it to a different PCI slot with no problems. Any insight would be most appreciated as the computer works great otherwise. Thanks!!
  • 596 Answers
One possiblilty is the VGA card may be bad. Try installing just the wireless card and booting your system, if it works install the VGA card. The other option, if you have not done so is to first install the software that came with each card and then install the hardware and reboot.
Good Luck
C2Solutions
Posted on Feb 04, 2010
After installing new ATI HD4670 video card on my Gateway zx6810 I boot system hear no beeps computer powers on but screen is black
Hello
Is this new video card the only video source on the PC (i.e. there is no other VGA connections on the PC)?
Without knowing the make and model of the PC, I will list the most common issue when replacing the video card in a PC.
1. Connect the monitor to each available VGA connection and boot the computer - to see if any VGA output is working
2. When you find a working VGA output, go into BIOS and change the VIDEO settings to either allow BOTH the onboard and add in video OR allow the add in video only. Save the changes and turn the computer off.
3. Move the video cable to the add in video card, turn the computer on and see if the BIOS is using the new Video card
Nov 03, 2013 | Sapphire ATI RADEON HD 4670, (1 GB) PCI...
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
Can i add a extra vga port to my compaq 1303wm
That all depends if you have available slot on your PCI or PCI-E buses. So let's say your running it from the built-in or onboard then you can buy a PCI-E card and install that with dual port capability. After you've installed the card you can then use both your screens simultaneously. One can be on a VGA and the other DVI port so just make sure you check out all the various video cards available. The only ones I would recommend is a GEFORCE card not an ATI RADEON. Okay so hope this helps you out.
Nov 16, 2011 | HP Compaq Presario SR1303wm PC Desktop
HOW CAN I INSTALL A NVIDIA GEFORCE 7200GS ON A HP 500B DESKTOP PC. IT IS CONFLICTING WITH THE ON BOARD VGA, THIS IS PREVENTING ME FROM USING THE GEFORCE AS A SECONDARY DISPLAY WHICH THE REASON I BOUGHT IT
It appears that you have spent real time and money to upgrade your system.
I understand your problem. You want dual output VGA's to have two monitors setup with your system. The computer, HP500 has an onboard VGA out, and your add-on PCI express will not give you a second out VGA.
More than likely, HP / Compaq might not support this configuration with thier CMOS>
Maybe better soloution would be since you already have a VGA and DVI video outputs from your new PCI express board would be to go into BOIS and disable your onboard VGA. The VGA should then revert to the new PCI express board. You then could connect the second monitor to have both on the PCI express board. If you have only VGA (blue type) connectors, you can get a DVI to VGA adapter.
At Newegg online or Tiger Direct should have them if needed for less than &10, plus S&H.
Good Luck
Aug 13, 2011 | Nvidia GeForce 7200 Graphic Card
Need to connect 3 monitors. Want to use either a Nvidia 290 or ATI Radeon 9250 plus the VGA port. Installing the dual-video card disables the VGA port, cannot get it back. Help!!!
Use your AGP dual-video card for two and using a PCI VGA card for the third. It is best if the same manufacturer video driver is used for both cards, as two different ones could be problematic.
Jun 25, 2010 | HP Compaq Business dc7600 PC Desktop
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Will a dell dimension 2100 support dual monitors
Yes it will but that will also depend on your graphics card to a degree.
To do it properly you need to install a new graphics card and disable the on-board graphics card from the bios.
Your new card should support std VGA as well as DVI
DVI is also capable of being hooked up to many large screen tvs
Aug 20, 2009 | Dell Computers & Internet
I can't video cards that fit within the confines of my computer housing
Good morning! please try to check with your acer aspire x1200 supplier if they have a bigger case that will replace the 4 inches wide case, in order to install a new VGA card. best regards
May 03, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Video Card
e800, is 18 years old now. wow, old as the hills or dirt. (like me)
not one video card stated, by you, name and numbers, wow.'
welcome to PCI express, PCI died long long ago.
but wait there is none this 18 year old server.... sorry, no express.
the e800 has 7 slots (ivory /white) all PCI of 2 types (legacy)
here are the proper names.
lets read the manual together, easy no, read?
but wait e800s are not express at all, period.
it has 5 32bit slots and 2 64 bit slots, (non PCI express)
page 19 (pdf) showsslots 1 to 4 are primary slots.
see those slot notices, those tell volts and bits.
this is legacy rules 18 year ago. and tricky interrupt rules max.
' a pentium 3 inside, what fossil. that is.
slots are limited to 33MHz.
(read slow as heck, gamer are you ,sorry this is bad fish)
watch out for code 021 errors. PCI
see page 96 (pdf page) see your card slot ID's there?
sure.
the big problem on any server, (its no workstation pC)
is video cards. added, later.
the stock VGA chip does 1600x1200? did it go bad?
the stock VGA card was a ATI RAGE XL
i guess lost , missing or dead. sure.
if still good? RAGE?
why is that not good enough(no usage application stated)
hint it will never do gaming at all, hint $60 games! in fact horrid.
the spec, book says some had a built in XVGA port.
does yours? on board?
a free manual. read how jumper and DIP switches work.!
https://www.manualslib.com/manual/1187338/Hp-Netserver-E-800.html?page=2#manual
the 1st 4 slots, left side are 5v slots, not 3.3v.
but dual voltage PCI cards work in both type slots.
slots long, are 64bit 5v slots, not 3.3v
but again dual 64bit work 3.3/5v dual cards.
e800-qmgpkmrqk2qyokndrzm3ifjy-5-0.jpg is this dead? please tell what you have here.
now I will toss coins for you.
coin 1.
1: is the RTC coin cell battery good. (pun yes) page 81 in manual
2: The XVGA jack above is dead. so owner wants to add a PCI card.
3: the old manual hints at dual video cards but fail to say how.
my guess is that the two, 64bit slots are in fact for this dual VGA.
SO buy one. card here, and try it,
it will cost more than the PC is worth for sure.
do not buy :
  • Express cards, useless
  • do not buy AGP cards, again, useless. straight gold finders yes. funny ones NO.
  • 64bit PCI is it. 5volt only or dual voltage.
  • do not buy 3.3v only cards, vast types sold..even used, vast.
the demand for such card today is near ZERO.
so are rare, now, and scalpers love to feed the rare folks needs, bingo.
so lets do newegg, as they have check box for PCI only
is why, few do that .
here are the players.
no hits, all are 3.3v, (3.3v means quasi modern)
5v cards are relics, 3 notch cars, are dual voltatge
and missing here.
sorry I cant find one here.
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pci+64bit+vga+card&N=100007709%20601296705&isNodeId=1
lets try scalper.bay. (I FAILED HERE TOO)
the problem is your mobo is not dual voltage mobo a very serous limitation in 2018 , no?
in fact most seller there are clueless that 64bit + 5v exists.
tons of agp and express and 3.3v there. only
id get a real MOBO, for sure.
here is the magic rule on old slots. here
http://www.pcdied.com/PCI_Keying.svg.png
right side 2nd one down, bingo 5v mobo.
Jan 02, 2018 | HP NetServer E800
HP Pavilion 753n (P9852AR#ABA) PC Desktop Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
