Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Black ink will not print. Colours ok
Brother dcp165C printer - nearly new. black ink will not print. Colours ok. Worked well for first sample cartridge but black ink will not print from new cartridge. Have tried 2 new cartridges.
  • 712 Answers
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
    President:
  • 2,306 Answers
Neither solution will help, Brother has had some bad printheads and the only repair is to install a new printhead. It's a shop repair and runs around $170.00. Under warranty there's no charge. The thing you really don't want to do is blow air into the system as it takes another full ink to get the air bubbles out. Sorry for the Stupid help above.
Posted on Feb 09, 2010
Why doesn't my printer print the black text?
With the printer in the ON position take out the black cartridge and put back again and make a sample test text page and see if its recognized and printed,.
Jul 24, 2014 | Brother MFC Office Equipment & Supplies
Brother- MFC 90CW black ink just replaced, but not printing, even the test print didnt print propaerly, it came out very light in other colours but not in black? what to do? is it a toner problem?
Thoughout my experience of fixing computers, I have seen this happen twice. Once was because the "new" ink cartridge was empty (which should cause the LCD display to say "cannot print"). the other was because the end user did not remove the protective yellow cap before installing the ink cartridge (yes, they made it fit). If neither of these are the cause you should try cleaning the print head. You can do so by pressing "ink", then scroll down to "cleaning", then scroll to black and press "ok".
Nov 06, 2010 | Brother MFC-5890CN All-In-One InkJet...
Printer won't print black ink
The black is always the first to wear out on the printhead. If you are using a refilled cartridge check the side of the cartridge, if you can see ripples near the hole at the bottom then the blotter material has been pushed up inside and can't contact the filter in the printhead. If all is good you will need a new printhead, QY6-0049-000
Feb 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Brother MFC 215C :yellow and red refuse to print
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 12, 2008 | Brother Multi-Function Center® MFC-215C...
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother mfc 210c printer
Check ink cart if it is well placed into the ink cart assy. Do the cleaning procedure by pressing INK skip the arrow-button down until CLEANING is displayed. Press start mono (blue button). After cleaning cycle you are asked by machine to print a quality test sheet. Do so and follow display instructions. Do the cleaning procedure a max of three times! When there still is no BK the printhead either is clogged or dryed out. Sorry, this cant be fixed anymore.
Oct 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
1,067 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
