Question about Samsung HL-R4667W Rear Projection Television
I replaced the colorwheel and the lamp. The TV powers up the lamp comes on and about 5 seconds later the lamp goes off and the TV powers off. Any ideas?
    Scholar:
  • 130 Answers
You may still have an issue with the color wheel. That or the ballast is bad. I don't think it's the lamp if you've just purchased a new one. It's possible that you've installed the color wheel wrong, or that the color wheel is defective.
Posted on Feb 04, 2010
TV has video for about 10 seconds after turning on and then about 5 seconds later audio goes and TV goes out - what is the problem?
Possible bad lamp, color wheel, or ballast.
Remove lamp and look to see if glass pillar in middle is straight and not bent from heat.
Color wheel faces the lamp--usually when or before fails you get a fan like or high pitched sound from it. Look to see it is not missing segments or shattered.
May 29, 2012 | Televison & Video
The picture come on then goes black and then the television turns off. I thought it might be a bulb problem (4 years old). So I bought a new bulb, seemed to work and then began to go black again with all 3...
when the colorwheels start to go bad this is the symtom that shows up. try this listen carefully to the rear of the tv near the lamp door. as you turn off the tv if you hear a slight grinding noise as the colorwheel slows down that means the bearings inside the colorwheel are dry and you will need to replace the colorwheel.
Mar 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Lamp replacement issue infocus in24+
either the lamp's seams aren't taped over with foil tape to prevent the premature shutdown due to the heat sensors being triggered, or the fan under the the colorwheel has stopped, maybe due to a piece of lamp from a previous lamp explosion being stuck in it, or the power supply/ballast is bad, or the eca on the engine itself is bad. The lamp is the easiest to try first. There should be foil tape over the seam on the side of the lamp you can't see when it is installed. If this doesn't work, take the front bezel off amd get where you can see the fan under the colorwheel and tunnel and power the unit up and see if the fan comes on. If it does thenthe eca on the engine or the power supply ballast is most likely bad and these are major repairs.
Feb 01, 2010 | InFocus Projector Lamp for IN24+, IN26+
When I try to cut on the TV all 3 indicator light start to blink.
listen to the tv from the rear you should hear a slight wind up of the colorwheel just after the power button is pressed. after that the lamp ballast should attempt to start the lamp . if the lamp is bad you will hear a buzzing and see no light coming from the lamp door. if you dont hear that winding up of the colorwheel its bad and needs to be replaced
Feb 01, 2010 | Samsung 50" Slim-Depth DLP HDTV
When watching tv on any mode...after a few seconds screen goes dark and sound goes out...then a few seconds later it all comes back...happends repeatly...any thoughts?
Time to replace Lamp in TV.
Existing lamp getting weak and causing that problem, replace lamp and TV will be fixed.
Buy Sony original lamp for TV safety and lamp replacement procedure is written in user manual.
Thanks.
Jan 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Samsung HL-R4667W Rear Projection Television Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
