Question about Dell Inspiron 1501 Notebook
Message= block 20560772 uncorrectable data hard drive
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
Hello sicily0144,
One possible solution is to open a cmd window and type chkdsk /f.
• The cmd window can be accessed by clicking on Start and Run. Then type cmd and click ok*
• Type 'Y' (Yes) if the following message displays when running chkdsk /f :
"Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N)".
Chkdsk will try to fix the bad block problem when the computer is restarted.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Feb 04, 2010
Windows has shut down to prevent damage to computer, Blue screen comes up every time and cant access not even in safe mode. -Error Codes: 650f : 0244 & 650f : 1A44 -Message: 185076...
Hello
This is a hard drive failure.Try holding down the f8 key while booting up and choose command promt.
Once there use Chkdsk .
Here is a link that explains how.This will check the drive and possibly repair it.If not you will need a new hard drive
http://support.microsoft.com/kb/315265
Aug 01, 2011 | Computers & Internet
I have a Dell Inspirion 8600. XP SP3 w/all of the latest MS updates. Got keyboard error message, rebooted and got blue screen related to keyboard error. rebooted, reset Boot menu to Dell factory default....
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 04, 2011 | Western Digital Computers & Internet
Dell won't boot up. The following problems isolated by F12: 3600:0123 Battery test failed 0F00:075D IDE device failed: the self test failed to read ... 0F00:0244 Block 1905 74359: uncorrectable data error...
sounds like a complete motherboard failure with a lot of other problems.
if you remove the HDD ( turn the machine over. 2 screws on the right.slide drive out ) and mount it in an external caddy you should be able to use another machine to access the drive and probably get most data off it.
Aug 02, 2010 | Dell Inspiron 6400 Notebook
Dell Laptop Vista repair stuck! My Dell Vostro 1500 does not start. It is Vista Home. So, I am trying to repair it with the installation disk. However, the installation stuck after the "Windows is loading...
leerobin
It does look like you may have a problem with the hard drive on the computer.
In regards to recovering your data if you have access to another computer you can connect the hard drive to it to see if the data is recoverable. Note since you ran the system recovery it may have over written your data. If this is the case then you might check with your local computer store to see if they have a hard drive data recovery program. As long as there is not a physical problem with the drive they may be able to recover the formatted data.
After that I would look at the top of the drive to see who the manufacture of the drive is then download there diag and repair tool for the hard drive. While you have the drive on the computer run a repair scan on the drive. If you just have some bad sectors then the diag program will zero them out and repair the drive. If the drive is indeed bad the program will tell you this as well.
If the drive is bad and your computer is still in warranty then you should be able to get Dell to send you a replacement hard drive. If you are not sure if you are still in warranty let me know the service tag of your computer and I can look it up for you. Also note you will want to have Dell send you your recovery CD if you do not already have it.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 20, 2010 | Computers & Internet
My OS freeze's as soon as i input my password
Hi there.
Sorry but i have to inform you that your hard drive is failing, the error messages that you are getting relate to this fact and is related to the hard drive having unrecoverable bad sectors or immanent hard drive failure.
There is no way you can recover the drive!!
Your only option now would be to buy a new drive for the computer or if the machine is still under warranty take advantage of that and send it in for repair, you will no doubt have to purchase a windows installation disk too.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Dimension 9200 PC Desktop
Error code 0244
Hi there.
Error Code 0F00:0244
"Msg Block 5*****4: Uncorrectable data error code or media is write protected"
Sorry to say the hard drive has failed or is corrupt with bad sectors, with these Dell drives there is no way of fixing them.
There maybe a possibility that you can recover your data if it still spins up and you add it to another computer as a slave device.
May 20, 2009 | Dell Computers & Internet
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
Laptop PC running XP Home Edition will not boot, error code 0F001A40 Msg: Block 43982261 Uncorrectable data error or media is write protected
It sounds like you have a corrupted hard drive you can try to restore to last known good configuration by pressing F8 when you boot up. If that doesn't work find your restore disk and select repair windows first. before installing new(all date will be lost) mysleuth
May 06, 2009 | Computers & Internet
Won't start
Boot using Recovery CD and run chkdsk /R C: to fix errors then reboot.
You may have to install a 2nd copy of XP which will trash the first copy but at least leave your data files intact.
Aug 07, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 1501 Notebook Logo
Alun Cox
