MONITOR GOES OFF WHEN USING POWER ADAPTER - Computers & Internet
  • 942 Answers
It might be the problem of your battery or your computer itself, consult technical support for assistance
Posted on May 11, 2010
My screen is black and wont power off
replace the cable that goes from your monitor to PC. Especially if you have a powered mini display adapter cable (if you have a video card that supports multiple monitors you will have a mini display powered adapter cable ) these power adapters burn out easily. 2 of mine were defective out of the box, I discovered defect by pure miracle.
Dec 11, 2013 | HP Pavilion F1703 17" LCD Monitor
Cant figure out where the power cord goes or even if it has one...
There are several Mag monitors that use external AC adapters that plug into the VGA cable. Look on the blue connector and you should see the hole where the adapter plugs. The adapter is 12v 5 amp such as this one.
http://www.ccl-la.com/catalog/product_info.php?products_id=48
Dec 03, 2012 | Mag Innovision InnoVision LT 765S 17" Flat...
I boot and my screen is hit and miss, so screens i see most i do not. worked intermitent, so times it would work, then it just stopped all together. i replaced the monitor and it works just fine. i then...
Which version of the monitor do you have? Built-in power supply or external AC adapter?
http://www.agneovo.com/us/content/f-417.asp
or AC adapter: http://www.usadapter.com/LCD-AC-Adapters/AG-Neovo-F-417-LCD-Adapter-12V-4A.html
If it uses externa; AC adapter, then you need to attach a car bulb such as 1157 using high filament to the adapter output and see if it still putting out 12vdc with load.
If it uses built-in power then you need to check the power supply section first.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 09, 2010 | Neovo F-417 17" LCD Monitor
When I power on my monitor it shows the adjustment menu for a second and then goes blank. if i press menu it falshes again. it is like it goes into power saver mode right away. it does this whether on not...
Definately it's not the power supply of the computer. Maybe it's the vga card of the computer. Try using the monitor with another computer or another computer at the monitor.
Stelios.
Feb 22, 2010 | Computers & Internet
Monitor not turning on
If the adapter goes out its most likely the adapter. Check the voltage on the adapter and try and match one up on the internet as the one you order from the company will most likely cost 10x more. You need to know the output voltage and amps.
Sep 21, 2009 | Planar WS231 23.1 in. Flat Panel LCD...
Monitor suddenly died..replug it and it has power for a couple of seconds but then no power..is the ac adapter the problem and needs replacing? or is the monitor history?
no no the monitor is not history yet :)... it's your adapter maybe. try holding the adapter tightly when you insert it. check the monitor while holding the adaptor.. that should help you find out
Aug 01, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Flashing on and off
Is the monitor a LCD monitor and does it uses a power adapter?
If this is the case then it could be the power adapter that is faulty or if it is underpowered and the thermal overload cuts in then it switches off and when it cools it switches back on again.
Check the monitors power specs and the adapter should match the power requirements of the monitor or greater (ie. the voltage should be the same but the current rating should be the same or greater).
Feb 10, 2009 | Dell Inspiron E1505 Notebook
Sceptre LCD Monitor
I did not have a power adapter for my lcd monitor but after 2 weeks of searching stores, internet and universal adapters I found the power adapter for my specific monitor on ebay. If that doesn't work I would suggest a universal power adapter.
May 28, 2008 | Computers & Internet
Mag Innovision LT582s 15 in flat monitor
Well, Most montiors have a standered adapter Which you can get from almost any good online store, maby say what the socket looks like most are 3 pin sockets..
Sep 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
