My HP printer has a message show that I have a print cartridge error. I cannot turn off the printer to inspect the cartridge. The message ''Shutting Down'' appears,however the ''ON'' and ''Cancel'' buttons will not respond .If I can turn off ptinter, I can examine the cartridges. Please help this old lady!! Thanks
    President:
  • 2,022 Answers
Just unplug the power cord and open the cover and remove the catridge and clean it and fix it.
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Have a nice day and do not forget to rate please...!
Posted on Feb 04, 2010
Testimonial: "I don't know which "hand" to click for rating, but the information you provided corrected my problem. Many, many thanks! ejddsalado@embarqmail.com"
  • 5,479 Answers
Disconnect the power cord. (I would recommend pulling the USB cable first to minimize problems with a confused computer.)
I hope you can find the cartridge problem.
Testimonial: "I can't tell which "hand" to click for rating; however, your suggestion helped solve the problem with my printer. Many, many thanks! "
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
Error message 0xc18a0201
try to reinstall your printer and if the error message show up again try to check your printer to the HP customer care mybe the problem from your board printer
Apr 09, 2010 | HP Photosmart C5180 All-In-One InkJet...
Error message everytime i print
the E error message is for 2 reasons.either its a paper jam in the printer or the cartridges r faulty.there r two cartridge 1colour and 1 black.as 1 of them may had gone faulty.just replace the cartridge and it will work properly.
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
What does 10.0002 supply error mean?
10.0002 Magenta cartridge e-label error Error message 10.0002 supply error alternates with Reinstall c00381084.jpg with a ? under the Magenta print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
  1. Open the front cover of printer and remove the toner cartridge exhibiting error.
  2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
  3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
  4. Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
  5. Reinstall the print cartridge.
  6. Power cycle the device.
  7. If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
  8. If the problem continues, contact HP Customer Support Center for technical assistance
Dec 03, 2008 | Office Equipment & Supplies
ERRO
The following solution was found at;
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00314875#A9
Cut & pasted here it is;....
10.0003 Yellow cartridge e-label error Error message 10.0003 supply error alternates with Reinstall c00381084.jpg with a ? under the Yellow print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
  8. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Nov 28, 2008 | HP Color LaserJet 2600n Printer
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
Printer refuses to print Error Message
i suggest you inspect the bottom, to see if anything is compromising the connection pad.
Feb 27, 2008 | HP DeskJet 950c InkJet Printer
69 people viewed this question
k24674
jasbo
jasbo
