Question about Garmin nuvi 200W GPS Receiver
Garmin nuvi gps navigator
I have a garmin nuvi gps, if i turn it on it just starts to flash the name garmin over and over, and it will not stay on. i have let the battery go dead and recharged it, but it is still flashing on and off.
  • 2,335 Answers
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Posted on Apr 17, 2010
I have lost all UK & Europe mapping - except for major roads. This was initially built in to unit. Have SD card for Australia & New Zealand - this works fine.
The maps are stored in specific mapset files with *.img extension in the flash memory of the GPS unit. Each mapset file contains one or many maps in it. Beside that, the Garmin GPS navigator can also recognise and load up one additional mapset file from SD card residing in the "Garmin" folder and named as "gmapsupp.img".
Here are the mapset files supported by Garmin Nuvi 255w GPS navigator:
  • gmapbmap.img - the default base map
  • gmapprom.img - the primary mapset
  • gmapprom1.img - the secondary mapset
  • gmapoem.img - the OEM mapset that cannot be unselect by user (if it exist)
  • gmapsupp.img - the supplemental mapset which you can have one in the GPS flash memory and another one in the attached SD card.
Therefore, the Garmin Nuvi 255w GPS supports up to 6 mapset files, including 1 in SD card. Normally new maps installed by the user will be stored in gmapsupp.img.
You will lost all the maps in the previous mapset file if it is overwritten by a new file with same filename. If you want to keep the existing maps, ensure that you store the mapset file with an unused filename (from the 5 filenames above). Alternatively, you can make use of special tools to merge new maps into existing mapset file.
You can view the name of your base map in Tools > Settings > System > About > Basemap.
You can view the name of maps in the other mapset files in Tools > Settings > Map > Map Info. There, you can tell the GPS to load the map by checking on its name, or not to use the map by unchecking it.
In case there are 2 or more non-overlaping maps available for the same location, the map with the highest priority number (defined in the map itself) will be used by the GPS.
Note that certain map which are locked by vendor need a 25 bytes unlock key stored in a *.unl file in the same folder and with the same name as the mapset file where the locked map is stored in.
You might probably also interested to read:
Mar 13, 2011 | Garmin nuvi 255W GPS Receiver
It will not power on. The name garmin is on the screen with a black background.what could the problem be?
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin wont stay turned on
I can help you reset and fix your Garmin Nuvi 265W.
Shutting down, freezing, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
I hope that helps.
Nuvi 265W Manuals here.
Jan 11, 2010 | Garmin Nuvi 265W GPS Receiver
My garmin nuvi 660 na is locked and i cant unlock it
There should be a small pinhole for a reset button. Press and hold this reset button for 60 seconds. Then turn the device back on.
Mar 25, 2009 | Garmin Nuvi 660 GPS Receiver
I have a garmin 265w that shut off by itself and will not turn o
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Feb 02, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin nuvi 360
I had the same problem. Sometimes the voice would start to speak and then cut off after a few sounds. I was still under warranty so Garmin replaced it (I think with a rebuilt I am now having display problems with).
Before I contacted them I tried software updates and resets and changing voices--alas it had to go back to the factory.
Jan 14, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin nuvi 200W GPS Receiver Logo
287 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
