Question about Nokia N70 Cellular Phone
Screen dirty How do I remove the front cover on a N70?
My n70 screen is flickering and nothing appears
Posted on May 10, 2010
    Genius:
  • 1,665 Answers
See analytic video here:
(http://www.youtube.com/watch?v=2BkaYtsi3J4)
Posted on Feb 20, 2008
    President:
  • 1,944 Answers
Here is pictured guide
http://www.allaboutsymbian.com/forum/showthread.php?t=43299
I cant open the main camera.
What is the exact problem....is the camera never open even if you move down the camera cover ? or Camera on Stand by or No image ?Here let me give you a trick to check it out that the camera is working or not.First remove the back cover, after this you'll see switch at the right hand side (will move downwards when we press).Just press there for 3-5 secs when the phone is in normal mode.And the same time look at the screen (front display).If the image is coming the problem is from the cover.Otherwise contact mobile repairing shop.Good luck
Feb 21, 2012 | Nokia N70 Cellular Phone
N70 BACK CAMRA NOT OPEN HOW CAT SOLV
Back cover is obviously very easy. Front cover has 4 clips one each side at top and bottom, just need to gently pull the casing away from the body in each corner until the clips pop out. The piece over the camera at the back is a little more tricky, it's got two clips, one each side at the bottom, check your back shutter it connected with a camera switch. Remove the back of your phone & then set it again.
Nov 26, 2010 | Nokia N70 Cellular Phone
How to open cover mobil nokia n70
There are 6 latches all in all. 2 in the bottom part, 2 about 1/4 for the top (in line with the top of your screen) then 2 in the top part. First remove the bottom 2 latches. I would suggest to use a jeweller's flat head screw driver or similar. Then slide the screw driver up one side to the latch that is about 1/4 from the top - it is in line with the top of your screen, this latch should pop off. The cover is fairly strong but do be be a little careful about breaking it.
Then the other do the same on the other side, after that every thing else is easy, pull the front cover carefully from the middle latches then slide the cover upward. If you do all this carefully then you will have successfully removed the front cover.vote me if this works.thanks!
Jun 16, 2010 | Nokia N70 Cellular Phone
The bottom of the screen has transparent green blotches
This model has a geometry mirror that is lies in the front of the cabinet. It is dirty and needs cleaned. Remove the middle front plastic cover, between the screen frame and speaker cover. Remover the screen frame, disconnecting the harness (4 screws are behing that middle cover ;). Clean the mirror and reassemble. Wipe the lens while you are in there and do not touch the big mirror... you'll really have a mess if you do. Also, use caution not to put pressure on that little mirror as you clean it, you'll mess up the geometry and end up with a trapezoidal picture.
Mar 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My n70 is just vibrating and not ringing and is
The LCD display connector is either loose or the LCD is faulty, the speaker contacts are loose or the speaker is faulty.. Other than that, you have to have it checked by a qualified technician. Follow the procedures below to disassemble the phone and check the LCD, connectors and speaker.
  1. Wear a pair of electro-static discharge (ESD) protective gloves.
  2. Unlock and remove the battery cover.
  3. Unlock the clips of the front cover beginning at the bottom by prying the latches with your fingernail or a prying tool one at a time.
  4. Carefully remove the front cover.
  5. Protect the display with a plastic film.
  6. Remove the 6 screws using a T6 screwdriver.
  7. Swing the user interface (UI) frame assembly upwards from the bottom. Bear in mind that the flex connector is still connected.
  8. Disconnect the flex connector carefully by prying it.
  9. Clean the connectors using a soft-bristle toothbrush with a lacquer thinner.
  10. Remove the engine board and place it in a cushioned non-conducting tray.
  11. Clean the speaker terminals and contact pads on the engine board using a cotton bud with lacquer thinner or alcohol.
  12. Lift up the speaker terminals to ensure it makes contact with the contact pads on the engine board.
  13. Check the resistance of the speaker using a multimeter. The resistance reading should be 20-30 ohms, otherwise replace speaker.
  14. Put back the engine board.
  15. Reconnect the flex connector firmly and reassemble the UI frame assembly.
  16. Remove the protective plastic film and reinstall the front cover.
  17. Insert the battery and turn on the phone.
  18. There should be a display and tone when the hands appear on screen. Otherwise, have your phone checked by a qualified technician.
Check this out for the complete disassembly:
Nov 24, 2009 | Nokia N70 Cellular Phone
My plasma screen has dimmed
i have been fighting a dark screen almos impossible to see dark scenes
i found this from another person
the mirror has dust on it easy fix
remove front of screen by removing screws around the top and sides of the back don't forget to pop off the bottom cover in the front it just pulls off
then remove center cover screws
i could not disconnect the front electrical plug but it has enough slack to lift and then tip the front screen down to the floor
it will be obvious on the mirrors there is a big one it wasn't to dirty
lean in and look down there is a small mirror and lens they were filthy
there is a piece of foam trying to keep the dust out it was sucked backed so dust could get in
clean with windex and paper towels cloth didn't work
good luck
Nov 08, 2008 | Mitsubishi WD-62525 62" Rear Projection...
N70 White display
its about display connector.follow display wires & try to fix the connectors
Nov 03, 2008 | Nokia N70 Cellular Phone
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Cleaning of mirrors
good luck
Apr 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dark picture ,cant brighten picure,
this worked for me
good luck
Apr 17, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Nokia N70 Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
