Question about Sewing Machines
Threading instructions for the lockstitch 2000
  • 161 Answers
Worth having a look on you-tube
Posted on Sep 14, 2010
  • chrisy8hunt Mar 27, 2011
    http://www.singerco.com/accessories/manu...
    Found this free download. Now to try to thread it :)
    If it asks you to search, just search lockstitch (not 2000) and it should take you there to download it.
2 Suggested Answers
SOURCE: need instructions for Singer lockstitch 2000
I have a singer lockstitch 2000 and cannot get the bobbin thread to work. Can you help me
Posted on Oct 04, 2010
Can incorrect timing adversely affect lockstitching tension balance, causing totally intractable tension issues?
Timing can affect a lot of things. However, there are multiple things that will present problems. Even the tension disks can be dirty or not working properly.
Usually the most common problem--the machine is threaded incorrectly. The best practice is when a thread breaks, comes unthreaded or is malfunctioning, remove all the thread and rethread from the beginning. First RAISE the presser foot before threading so the thread will seat properly in the tension disks. Check to make sure each thread is threaded in the correct order or the machine will most likely never work well.
Jan 28, 2016 | Sewing Machines
My thread cutter cuts the top thread with every stitch
that is a possibility and is a reason that I don't use self adhesive velcro any more
I just put in a new needle and that fixed the problem
if it started with the velcro then that should fix it
Jun 19, 2015 | Great Plains Ind. Juki TL-2010Q 1-Needle,...
When my machine sews you can pull bottom thread right out of the stitching
First - Thread it with 2 completely different colors of the same size thread; 50 weight is best.
Your upper thread tension is too loose, turn it clockwise a quarter turn, test the sewing, repeat until the sewing is good.
Jul 16, 2014 | Great Plains Ind. Juki TL-2010Q 1-Needle,...
I need manual for Smartek RX-07 Mini Rex Cordless Sewing Machine
How to thread a sewing handheld machine rx-o1r
Dec 12, 2011 | Sewing Machines
The needles I have are round shafted, ( no flat side ). Which way do I face the small recess where the eye is ? My machine was given to me. It's self oiling. What type of oil should I use? And where can...
hi there
concern needle attached if your machine lockstitch machine you are use DBx1 and easy to attach just keep in your main at any machine the small flat must be obosit saide from you threading the thread.at lockstitch machin small flat must be at ur right hand and the long at ur left hand .concern oil you can use juki defrex No.1 or light clear oil for industerial sewing machine.
Oct 28, 2010 | Juki DDL-8300
My Juki industrial machine will not pick up the lower thread and it wont keep a stitch going. Why wont it pick it up anymore!!! I really need my machine!
hi there
can you please tell me your machine model? i can help
any way if lockstitch machine you must first make sure you installed needle correct way and you are use new needle
can you check hight od needle bar is ok if you move it up and dwon?
can you check timing between needle and tip point for hook?
i can send page from instruction manual how to adjust hight of needle bar and timing with hook.
best regards
ashraf abozid
aabozid@hotmail.com
Sep 02, 2010 | Juki Sewing Machines
The top thread keeps breaking, I have tried with different threads and needles
hi htere
if ur machine is lockstitch try to use new bobin case or readjust the screw for spring. normally we change bobin case with new one also try to send ur machine model to any one can help u on site
best regards
ashraf abozid
aabozid@hotmail.com
Aug 16, 2010 | Sewing Machines
Need threading instruction for white sew ez plus childrens machine
Raise thread spindle by graspi G the expose s too and pulling up wears until thread spinale is fully extended, Place thread spopola on the three ad spindle. Pull thread from the thread on the thread spopola on the thread spinale and put it through the thread holder in the direction toward front of macchine. Bring thread a cross to the thread tension screw. Thread goes over the tension adjusting screw and must be position ed between the two washers beh ind. The tension adusting screw. This is what provides the lockstitch tension to the thread. Pull thread from tension adusti G screw guide through thread take up lever in the directions tovwarped front of machine. Pull thread through thread guide inserting in the direction tosare the front of the machine. pull thread down to thread guide and insert thread from the top downward. If necessary, loser the neede to reach this guide by turning the handwheelslightly counterclockwise (in the directions foward you) to loser the needle. Raise the need le to reach the eye by turning the handwheel slightly counterclockwise (toward you) insert thread through eye of the needle from the front toward the back of the machine ( use threader accessory if necessary) raise the presser foto by lifting up on the lever st the rear of machine. Pull about 10 inches of thread through the needle and lay it on the deck under the presser foot running in the directions away from you.
Feb 14, 2010 | Sewing Machines
Need instructions for Singer lockstitch 2000
Jan 28, 2010 | Sewing Machines
Which way to put the needle in the Juki, The
The indent is called the scarf.
The scarf will be at the 3 o'clock position and, if you look closely, you will see the hook pass the needle at the scarf.
Oct 01, 2009 | Juki DDL-8300
Sewing Machines Logo
1,104 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
