Audio fine but I press a button on the remote and lost video
  • Steve Olin Feb 04, 2010
    Toshiba DVD Video Player purchased in 2006 model #sd3990su
    I purchased this unit to watch dvd's in region 2 format
    It works perfect until I pressed the wrong numbers and/or letters on the units remote
Make and model?
Posted on Feb 04, 2010
How do i control a Nakamichi RE-1 with a GE Universal Remote?
The Remote has Learning Mode - change the operation of the remote to Learning Mode and program the key buttons appropriately by pressing buttons on the receiver with remote pointed at the receiver
Jun 19, 2015 | Nakamichi RE-1 Receiver
Tip
Service menu codes mitsubishi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
on Apr 29, 2015 | Mitsubishi Televison & Video
Lost sound to the dvd player
I think you mean you lost the audio input from your DVD player. My DVD remote has an audio button. Perhaps you pressed that
Nov 04, 2012 | LG V271 DVD Player/VCR
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
I have a Coby dvd 505 home theater system and it's playing dvd's only in black and white Any suggestions?
There are a few possibilities. 1) You have the system on wrong broadcast system. Press the TV.Sys button on the remote. (In the US, you need the NTSC (analog) broadcast for older TVs). If you have lost the original remote, you need a replacement that matches the feature. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12937326385240&smodel=DVD505&brand_pn=COBY_DVD505 for a substitute remote. 2) You have mismatched cables/inputs.
For the second issue, a composite video cable could be connected to a component video input. If both devices have component video, get a component video cable (red, blue and green for the video, separate red/white cable for audio); it isn't included with the player. Otherwise connect to the composite (AV) connections on the TV (yellow for video, red/white for audio).
If needed, you can reset the player as follows:
****RESET THE DVD PLAYER BACK TO THE DEFAULT SETTING***
1) Open the DVD tray.
2) Press the "Setup" button.
3) On the "Down" arrow, press it three times.
4) On the "Right' arrow, press it once.
5) On the "Down" arrow, press it three times
6) On the "Right" arrow, press it once, then press "Play/Sel" button.
7) Press the Setup button to exit.
*The default setting will take affect as soon as you press the setup button (step 6).
I hope this helps.
Dec 30, 2010 | Coby 5.1 Channel DVD Player with Home...
Lost remote
I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote. Another reply mentioned using a duraband model instead of Emerson and it worked for him.
Apr 20, 2009 | Emerson EWF2006 TV
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
I have lost the instructions for the jumbo universal remote.
a.gif Start by turning on the device that you want to program.
(1) Press & release the device button that you want to program, lets say "VCR" LED will flase once
(2) Press & hold the "CODE SEARCH" button until the LED stays on.
(3) Press and release the POWER button. Point the remote at the device.
(4)The LED will flash as the remote is searching for the code.
(5) As soon as the device turns off press and release the "ENTER" button.
The remote should NOW be programed.
Jan 23, 2008 | Audio Players & Recorders
Avr 1804 denon 7.1 reciver
Did you check the Audio-Video slider button in the middle of the remote? It needs to be on Audio, else the remote sends video channel number signals when you press the numbers.
Dec 26, 2007 | Denon AVR-1804 Receiver
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
