Question about Kenmore 24 in. 15689 Built-in Dishwasher
RANGE DOOR WON'T OPEN , RAN THRU CLEANING CYCLE,LET COOL DOWN AND STILL WOULD NOT OPEN.MODEL NUMBER 911.455881C
  • 129 Answers
Lock lever may have some in latch . may have to take apart and adjust locking lever and switch
Posted on Feb 04, 2010
Whrilpool gas range Mod. GW395LEGD0 Serial IMJ0663181 OVEN DOOR LOCKED CAN NOT OPEN
If its a self cleaning model and you tried to stop it in the middle of the cleaning cycle the door will not unlock. Disconnect it from the power, let it stand a few hours then plug in. If not opening try running the self cleaning mode and let it finish completely. When it finishes after it cools down sufficiently the door lock should go off.
Aug 09, 2014 | Whirlpool GS460 Gas Kitchen Range
Model number FGEF3032KWB frigidaire oven door won't unlock
Unplug, or turn the household circuit breaker off to the unit for about 15 minutes. If the door does not unlock itself then, contact Frigidaire for a service call. The door latch and/or control board will need to be replaced.
Aug 02, 2012 | Frigidaire FEF336BC Electric Kitchen Range
After running self cleaning cycle cannot open door...
Hi and welcome to FixYa, I am Kelly
The Range has to cool down before the door can be opened due to the safety interlock thermostats. If you just ran the self-clean cycle unplug it (or turn off the Circuit breaker) and let it sit for 2 hours and then try to open the door by pressing the stop/cancel button for more than 3 seconds.
IF this does not work just respond here and I will pass the instructions of how to manually open the door. There will also be troubleshooting required to determine WHY the dook lock is not functioning.
Thanks for choosing FixYa,
Kelly
Mar 15, 2011 | Jenn-Air Ovens
Kenmore elite 2 oven range. Ran the lower oven thru the clean cycle and now the door won't unlock. Tried shutting off electricity but that did't work. Neither did holding stop button for 3 seconds.
Sorry to read about your problem, I hope this helps you out.
the oven needs to cool down a lot before the door lock will release.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Kitchen Ranges
Kenmore self cleaning stove: cannot open door after cleaning cycl
F9 is your oven sensor im sure.Also try to unplug your range and plug back in.Some times that works.Hope i helped:)
Mar 13, 2010 | Kitchen Ranges
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kenmore 24 in. 15689 Built-in Dishwasher Logo
44 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
