Question about Dishwashers
My dishwasher, now 12 years old I think, is not cleaning the dishes as well and I find the walls of the dishwasher are dirty as well. Is it worth a repair call?
  • 129 Answers
Yes it needs cleaning remove bottom rack screws in motor cover vac out water wash all parts and screens by hand in hot water . set water heater to 130 degrees temp if no children are in the house. if yes only 125 degrees
Posted on Feb 04, 2010
Testimonial: "This is useful information. I'll try the solution and see if it works."
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
Dishes not clean after cycle!
Is the water coming into the dishwasher and is the wash motor working or is the sump clogged up so the water cannot get thru.Depending on the purchase date of the dishwasher, if it is a under a year old call who ever you bought it from as it usually comes with a 1 year manufactures warranty.
Feb 06, 2010 | Dishwashers
My 6-year-old dishwasher is not getting my dishes clean. glassware feels gritty; flatware looks dirty. I've tried cleaning the interior, and running a potscrubber cycle with the dishwasher empty except for...
Do a web search on "kitchenaid KUDP01FLBL2 not getting dishes clean". All sorts of reasons pop up. Some are easier to correct than others depending on how handy you are.
Good luck on you troubleshooting
Jan 16, 2018 | KitchenAid Dishwashers
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
Ultra Wash
Sounds like your not getting water to it. Turn on and let run for a few minutes then open door and check to see if you have water in it.
If not check to be sure water to it is turned on. Check float in front corner of dishwasher to see if moves freely up and down and that there is nothing underneath it. If these check ok you probably need a water valve.
Nov 03, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
