Question about Sony KP-53S35 53" Rear Projection Television
How do I clean the mirrors on my sony tv? - Sony KP-53S35 53" Rear Projection Television
    Scholar:
  • 130 Answers
You should not attempt to clean the mirrors on the Sony TV because that can damage the picture quality.
Posted on Feb 04, 2010
I have a ten year old sony 42" grandwega the picture is real dark even after Installing new bulb and cleaning front mirror. Is there a way to clean the color guns and mirror Iin back of tv?
Entire light engine as a unit should be replaced with this much older TVs. Contact the authorized service centre for Sony; to know the availability of this part. Nothing more can be done. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 16, 2014 | Televison & Video
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and...
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Mar 20, 2011 | Sony KP-53N77 TV
My Sony KP53S35 rear projection TV has a very dim picture and I was told that I need to clean the mirrors. Can you tell me how to take apart the TV to get to the mirrors and how to clean them?
chance are your problem is the projector lamp and not the mirrors. if the tv is 4 years old or more buy a new lamp, they are easy to change. as far as the mirrors go, you have take the back off to get at the mirror but its a lot of work try the lamp first.
Mar 12, 2011 | Televison & Video
How do i clean mirror on a sony KP-57ws520
Fairly easy to do.
Follow these steps:
1) Unplug the TV
2) Remove the lower access panel (the pressboard with all the holes in it) by removing the screws holding it in place. (This is the panel where where your connections are made)
3) Remove all the screws on the big black shroud on the back that actually holds to mirror. There are probably about 15 screws.
4) gently lift the panel off and set in on the floor or table where you can clean the mirror. (remember the mirror is attached to the back side of it) I usually put in on the floor.
5) clean the mirror with glass cleaner or non-streaking solution.
Reverse the steps above to re-assemble.
Feb 18, 2011 | Sony KP-57WS500 57" Rear Projection...
What do I use to clean the mirror on my sony vega single bulb tv
I have used windex and a paper towel to clean glass mirrors every day for over two decades with no problems. However use warm water in a damp cloth for the screen and if the mirror is mylar instead of glass leave it alone unless it is very dirty, then use damp cloth with water also. For the lense you can use windex and paper towel also, but just go over it lightly. Hope this helps, Russmann.
Jun 10, 2010 | Televison & Video
Blurry picture
Just a shot in the dark but the first thing i do when i get a blurry rptv in my shop is clean the mirror. Dust can accumulate and create a blurred image. You must be careful however as some of the mirrors are Front Surface mirrors and require special cleaning solutions/techniques. If thats the case using a damp cloth could ruin the mirror. I hope this was helpful.
Jun 05, 2009 | Sony Televison & Video
Sony 46'' WEGA TV
The mirror assembly has no moving parts, this unit has a minimum of 3 fans! if the fan blades get too dusty the fan will get noisy. Try cleaning the fans with compressed air.
Jan 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Mar 31, 2008 | Televison & Video
Sony 52 inch hd widescreen projection tv
You need to pull the top back off be very carefull that you do not break mirror clean mirror and all 3 tube lenses this should make a diffenrents in picture.
Feb 19, 2008 | Televison & Video
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
Televison & Video Logo
136 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
