I have a ecs l7vmm7 motherboard. I only had 1gb of ram (2 sticks of 512mb). I replaced those with 2 1gb sticks and now my computer monitor is black and i'm not sure that it is even booting up. help!
    Problem Solver:
  • 12 Answers
You have to make sure that the 2 rams are of the same frequency or the actually work by inserting them 1 at a time
Posted on Feb 04, 2010
Hi guys, i have installed 2 sdrams pc-133 512mb,together 1gb, but yhe bios and the system shows me only the half memory,whyyyyyyyy
Are you sure that both sticks of RAM are properly "seated"?
How much memory is found when only one stick is used?
How much memory is found when only the other stick is used?
Which motherboard? Some very-old motherboards only support a maximum of 256MB per slot.
How many memory-chips are on each stick of RAM?
If you have purchased "high-density" memory (small number of memory-chips),
and your motherboard only supports "low-density" memory, then only 1/2 or 1/4 of the actual RAM will be used.
Feb 17, 2011 | DFI CA63-EC Motherboard
Hi Dear ; When I install memory RAM of 1.0GB .. get ERROR
Cant find your motherboard on the support page, is the memory your trying to install the same speed?
Jul 16, 2010 | Intel Computers & Internet
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
Total amount of RAM not recognized by computer
are the modules the same specs? you may have some incompatibality between them. the board may be reading the ram right it may be you have four 256 sticks instead of 2 of each. read the motherboard manual it might shed some light here.
Jul 13, 2009 | Computers & Internet
EMachine T6534 Ram Issue
did you try putting 4 1g stick . instead 2 1g and 2 512?
Jan 16, 2009 | Computers & Internet
Everything works, but no display
Try a different stick of RAM. Like a smaller amount. try 512MB and see what happens. if 512 works, try the 1 of the 1GB sticks so you can still have atleast have 1GB.
Jun 11, 2008 | ECS 945P-A (V3.0) Motherboard
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
ECS 915PL-A2 motherboard RAM upgrade
try to reset the cmos first so that the bios would refresh
Dec 23, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Motherboard capacity
Can you get me the motherboard Model number ?
Dec 16, 2007 | Intel Motherboard
Upgraded Ram Issues
check the voltage on your new ram.
For ddr2 you need both slots filled.(this the memory I would use)
Make sure you put it in the right slots.
make sure that BIOs recognises each stick.
Let me know if these work for you.
Nov 30, 2007 | EliteGroup P4M800PRO-M478 Motherboard
Computers & Internet Logo
David Payne
David Payne
