Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Dishwasher f1 problem on fisher paykel
By inday5 on Feb 20, 2008
fisher paykel 920 dishwasher
Same Problem
Nov 18, 2008
-   water standing in the bottom of the tub-   Guest
Apr 10, 2008
-   will not drain-   Guest
Best Solution
posted on Feb 21, 2008
Very Helpful)
K395331181
Rank: Apprentice
Rating: 100%, 3 votes
谢谢啦
Was this helpful?
Yes
No
Solution #2
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
先谢谢啦
Solution #3
posted on Oct 14, 2008
Very Helpful)
FAITHALONE
Rank: Apprentice
Rating: 98%, 3 votes
PROBLEM WITH F1 ON A FISHER PAYKEL DISHWASHER
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Feb 20, 2008
Helpful)
jsrock516
Rank: Guru
Rating: 96%, 7245 votes
All the information that I have found about this particular problem indicates that the "F1" error is a flood or overflow alarm. It's generally caused by a clog in the drain line and/or tub not sealing properly when closed.
If this is a drawer style dishwasher there is a lid in the equipment cabinet that must seat properly on the drawer when it is closed. If you place items in the dishwasher that are too tall for the drawer lid to seat properly, it will not seal and water will splash over the sides of the tub during the wash cycle.
Another common problem is a clogged or kinked drain line. Remove the drain hose and make sure it is not plugged. Check it at BOTH ends.
The alarm is activated by a float switch in the bottom tray of the dishwasher. Look to see if this is any standing water in the bottom tray. If there is any water, or signs of wetness, the alarm will not clear until it is dried out. I found a couple of recommendations to clear the alarm. The first involved removing the dishwasher from where it is installed and tilting it at a 45 degree angle to pour any standing water out. Another method is to dry the bottom out with towels as best you can, and then use a hair dryer to dry any residual water. I hope I'm on the right track with this and I hope this solves your problem. Post back if you have any further questions.
CAUTION: UNPLUG the dishwasher or turn off the breaker BEFORE servicing inside the cabinet.
Was this helpful?
Yes
No
9 people thought this was helpful
Solution #5
posted on Apr 05, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thankful
Solution #6
posted on Apr 11, 2009
Very Helpful)
steel69
Rank: Apprentice
Rating: 100%, 1 votes
I found the problem on my F&P Nautilus dishwasher was caused by a faulty door seal allowing water to leak into the bottom of the unit where the pumps and overflow / leak sensor dit. I found this by removing the front panel from the dishwasher. The float switch (see photo) had activated. Replacing the door seal fixed the problem
Was this helpful?
Yes
No
Solution #7
posted on Jun 26, 2009
Not Rated)
hadago
Rank: Apprentice
Rating: 0%, 0 votes
The drain in my sink was a bit blocked, in that the water in the pipe was higher than the drain tubes coming from the machine, once this was all cleaned out it has worked fine.
Was this helpful?
Yes
No
Solution #8
posted on May 24, 2009
Not Rated)
mitchellcris
Rank: Master
Rating: 83%, 5 votes
well instead of going through all the wires i turned the tap off and electric on and pressed off on the washer (O) screen was black so i closed and it starts (if there is water in there) and it will drain all the water after that i started it and it was working. i lator found its the ballon the stops the door from opening was blocked so it cant seal by a cup/big plate so it cant drain it so now i never let it go near 3cm near edge so it can seal and is problem free since (6 months)
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
I need the user manual for my Bosch SGS45C02GB dishwasher
Answer
None of the manual cycles operate when the touch pad is pushed: Heavy, Normal, or Light wash.
Answer
My Whirlpool dishwasher suddenly stopped working in the middle of a cycle -- none of the lights on... (More)
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Van Nuys, CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
