Ahuh..remove that usb controller, and then do a hardware scan for differences should work well
and by the way, got backup for that Dell?
w7 First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK". Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers". Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts hope it helps
w7
for xp or earlier
if you need more help with this or if i have missed the problem post a reply
hope it helps
w7
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
click start control panel administrive tools computer
could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to
fix the problem
up on them dust will cause static and a lot of unforeseen problems for a
click start control panel administrive tools ,computer
management ,device manager look through all of your devices if you see a yellow
question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this
download are drivers for VIA USB 2.0 host controller on a system running on
Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows
2000/XP are not available for download. They are supplied on CD with new
mainboards or available through Windows Update. This version is a bug-fixing
release.
hope this helps
not recognizing modem
