Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
The auto defrost on my Whirlpool refrigerator model 310/350 isn't working and the refrigerator is very iced up.
    President:
  • 1,891 Answers
Cant find your model # but you know what its doing / so to correct this problem its one of two things . the defrost timer ( some times called (A D D C ) aditive defrost control . or the heater /thermo in the back of freezer . most comon it adc. mm hope this helped . feed back pls ..
Posted on Feb 04, 2010
Freezer coil, inside freezer compartment continues to freeze to a solid block of ice. Apparently the auto defrost isn't working. I can manually shut it down, thaw it and restart. It works fine for...
Your defrost circuit is made up of a defrost heater, defrost thermostat and a defrost timer (generally, but will depend on make and model). They are relatively straight forward to troubleshoot and replace, and not that expensive.
Suggest you go to www.searspartdirect.com and plug in the model number of your frigerator and look up the parts you need to get an idea of how much they are. NOTE: Sears isn't the cheapest place to buy the parts, but they use the real part number for further research.
Sep 10, 2011 | Frigidaire Refrigerators
We got a used whirlpool refrigerator with ice maker last year out of some houses that were being demolished. Was a good looking clean appliance and ran well. Last Saturday my husband got some ice out and...
kbyhybtmjd.gif Find defrost timer (#4) and advance it by placing screwdriver into slot. Do this till you here a click. Unit should advance into defrost after a few minutes it should go back to refrigerate.
Jun 12, 2011 | Whirlpool Refrigerators
Freezer is too cold and icing over into the refrigerator - also makes a noise when the door is open and then shut. Refrig is not staying cold at all. HELP
It sounds like your automatic defrost cycle on your refrigerator is not working.
Try manually defrosting the fridge.
If this works then you will need to get the auto defrost repaired.
Mar 31, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an upright Whirlpool side by side fridge freezer, there is ice build up inside under the ice bin/water dispense, I emptied the ice and turned off the ice maker but it is still there and getting...
It sounds like the auto defrost cycle has stopped working.
Manually defrost the freezer.
If things work better then it is the defrost cycle which is faulty.
A technician can help you with that
Mar 30, 2011 | Whirlpool GAFZ21 Bottom Freezer...
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Not defrosting,getting ice in vents.
Do a manual defrost, the auto switch short circuits sometimes, and therefore if manual defrosting works then you got to replace the auto-defrost circuitry. Also check if the thermostat is all right, otherwise that need a change too.....................................sodeep
Jul 30, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirlpool Refrigirator
water is probably caused by ice blocking the drain for the auto defrost. take off the back panel and you may see ice accumulating at the bottom of the evaporator. switch off, clear the excess ice with a hair-dryer used carefully and make sure water runs down the drain freely. ice in the drain may take some clearing - boiling water and patience are needed
Apr 14, 2007 | Whirlpool GS6NBEXRQ Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
354 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
