Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Can I get an Ice Maker for A Whirlpool ET1PHKXPQ 21 c.u. unit???? It looks like everything is their, just can't find a kit that says it will work on this model
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
SOURCE: no water to ice maker
We had a problem with ice maker not making ice. After alot of concern it turned out we just needed to replace the filter.
Posted on Aug 07, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: Refrigerator Ice maker stopped working after power outage
Check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 26, 2009
My IM115 frigedaire ice maker, doesn't seem to be making ice fast enough
The key to ice production is temperature, so if the unit is running at "0" the fan also has to run to cool faster. That a good look at these items and see where the issue may be. In this environment point blank information is the only way anyone could assist you. Lack of information causes no response or incomplete answers. Check the temperatures also check the ice maker for pealing or flaking mold issues. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 25, 2014 | Frigidaire Im115 Im115 Ice Maker Kit
I have a Whirlpool Gold GD22DFXFW02 side by side fridge/freexer with ice maker and water dispenser. Besides the fact that the water dispenses very slowly, the ice maker has stopped making ice. It appears...
Sorry to read about your problem, I hope this helps you out.
yes no water to the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Whirlpool Refrigerators
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
first ch3eck to see if there's ice in the fill tube blocking the water. if that is the case then you will have to replace the solinoid valves on the unit.
Apr 03, 2009 | Whirlpool GS5SHAXN Side by Side...
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Dec 17, 2007 | Kenmore 21.7 cu. ft. Side-by-Side...
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Pin retainer broken off from ice dispenser housing
Ill be gald to help you here....The people who answer the phones must be worthless, anyway the part number is 8201756 (ice door kit) it will probably have to be specially ordered, i have installed several and there not exactly easy but it can be done with some patience. Pass this along to your repair guy as he is not giving people correct advice.
Oct 09, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
237 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
