Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
I have a KitchenAid side-by-side stainless steel refrigerator. (Model KSSC48QKS00). The temperature of the feezer stays around 25F even though I set to 5F. I powered it off, and powered it back on after a few minutes. I waited 24 hrs, but have the same problem. The fridge seems to be working fine.
  • zhiling99 Feb 06, 2010
    Thanks for the suggestions. We cleaned the condender coils, which wasn't bad. It didn't help. We had to call for services, and ended up paying $1500 of labor to replace the consendor :-( At least, the part is still under warranty.
  • KitchenAid Master
  • 43,501 Answers
My first question would be to ask if it is running all the time or not...if it is turning on and off then you have a thermostat sensor problem.
However my quess would be that it is running contiuously and just can't make it cold enough to turn it off.
The reasons for this could be that the condenser is pugged with dirt and dust so the the heat is not removed. Usually this is under the fridge and a little fan blows air across it.
The other reason could be that you have a very slow freon leak and the charge is not enough to make your freezer cold as you want it. I would blow out the condenser coil frist and then have someone check the charge if that does not work.
Check out this tip on cleaning the coil
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Heatman101
Posted on Feb 04, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Feb 06, 2010
    They replaced the compressor or the condenser???
    It's great that you got it covered under warranty though!!
    Wow, 1500.00!! I could buy a pretty nice new fridge for that!!
    Glad that it all worked out for you anyway, something must not ahev been right from the get go on that unit.
    I do hope though that there is not a slow leak in there somewhere...
    Good Luck!!
    Heatman101
Temperature in the FF side dropped to low
Hi Steven,
Sensor / thermostat problem.need to replace.
regards,
nuwan.
Jan 27, 2014 | GE Profile PSW26P Stainless Steel Side by...
If my Kitchen Aid KSF26C6XYY00 door is in fact made of stainless steel, why do fridge magnets stick to it? Ohter people I know that have stainless steel fridges say that the magnets do not stick to t
Stainless steel is a term for a family of high chromium steels, some of which do in fact stain, although they do not rust as ordinary steel does.
The more expensive 'austenitic' stainless is non-magnetic, but harder to work into product shapes. 'Martensitic' stainless is a little more prone to staining and corrosion, but easier to work with, and is magnetic. Then 'ferritic' stainless is even cheaper, but less corrosion proof, and is also magnetic.
So yes, many stainless steels are magnetic, and if the manufacturer has not used the very most corrosion proof but expensive grade, then you will see it in that way. I would not see much reason for a fridge door to be made from austenitic stainless.
Feb 17, 2012 | KitchenAid KSF26C6Xyy Side by Side...
What is the price on this refridgerator
The lowest price I could find for this product was $1449.00, but the model has been discontinued, it is replaced by the KitchenAid Architect Series II KSRG25FVMS 25.3 cu. ft. Side by Side Refrigerator (price $1479.00) with 3 Spillproof Glass Shelves, Humidity-Controlled Crisper, External Ice/Water Dispenser with In-Door-Ice Dispensing System and FreshChill Temperature Management System: Monochromatic Stainless Steel
Apr 04, 2011 | KitchenAid KSRG25FKSS Side by Side...
Vegges frozen...ice in ice maker melting GE model PSW 26 LSRD refrigerator
Checkthe freezer temperature. The proper freezer temperature should be around 5degrees. The warmer it is in the freezer, the more difficult it is to make ice.
Jan 27, 2011 | GE Profile PSW26P Stainless Steel Side by...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Kitchenaid refrigerator surba ksrb25 ice maker inop
check feezer temperature. should be 12 degrees F or lower
Apr 30, 2010 | KitchenAid KSRB25FKSS Side by Side...
The refrigerator is tooooo cold.
Check for a set temperature button or anything similar on both the sides of the fridge. Use that tool to set it to your desired temperature.
Apr 22, 2010 | KitchenAid Architect KBFA20ERSS Stainless...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
44 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
