Question about Hitachi 53UDX10B 53" Rear Projection Television
The red power light won't go off when i turn off the tv.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The model indicated (53UDX10B) has two mechanical relays---one is stuck in the on position---
If you follow the power cord inside the set to the power supply board you will find two that look like the ones in the attached photo---you can as a temporary solution unplug the set and tap on each of them with the handle of a screwdriver.
That should clear the problem but at some point it would be a good idea to replace both of them--about 4 dollars each from Hitachi.
Understand--when the power light is on the set is powered up and running--just the sound and video are not on---not a good thing as the set can over heat and develop real problems--not to mention being a fire hazard.
I am also including the part number and location numbers for you for this model.
SD Tech
Hitachi FJ00142 S901,S902 RELAY, POWER/AUDIO
Posted on Feb 04, 2010
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
TV HAS RED LIGHT SHOWING WILL NOT SWITCH ON
Hi, The red light shows there is power connected to the set. The fact that it won't power up is due to a problem with the power supply circuit in the set. or a problem with the switch circuit or the mains power transformer. Regards John Ps don't know why they're giving me these questions, I answer questions on auto's
Feb 12, 2012 | Wharfedale Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Hitachi 53UDX10B 53" Rear Projection Television Logo
146 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
