Question about Refrigerators
GSS25WGPH CC,, unit three years old, am getting
GSS25WGPH CC,, unit three years old, am getting no water from front water nozzle. I ce continues to make...just no water, thing I hear a relay or solenoid upon presing the cup switch. Help
    President:
  • 1,515 Answers
Hi, it sounds to me as though the solenoid for the water dispenser is energizing when you push it but may be plugged up with water deposits I'm not sure how this dispenser is set up or if there is a way for you to get to it and check this out. I would turn off the water at back and see if there is a way to get inside to check for a blockage of some kind. I'm betting there is. Check and see what you can do about cleaning it, and also turn off the power as there is voltage to the solenoid. Keep me posted on what you were able to do on this.
Sincerely,
Shastalaker7
Posted on Feb 04, 2010
Remove nozzels for cleaning on a neff coffee machine
All you need to do to get at the nozzle unit (which gets blocked over time with fine coffee sludge) is to press the sides of the rear part of the nozzle casing to release the four clips on the sides and simultaneously press the bottom up to release the bottom clip and the front will just pop off. The nozzle unit will have to be in the lowered position.
Once you have the front off you can simply remove the delivery pipe to the nozzle unit and pull the nozzles out and give it a good clean. Soaking in hot water helps - you will be amazed by how much crud is in there.
Sep 26, 2014 | Coffee Makers & Espresso Machines
I runned the head cleaning procedure at list 15 times and the nozzle check pattern of the black color still presenting gaps. I use my prinyter twice a month for two or three large printing, thet's all;...
You definitively do not use the printer often enough and you probably have a CLOGGED nozzle you have to un-clogge it by disasembling the print heads and dip the nozzles in hot water NEVER USE ALCHOOL as it wil damage the heads, you could try delicately presurise hot water with a suringe with no needle through the ink intake hole... remember to put some absorbing material underneath the print heads when DELICATELY injecting the HOT water
Feb 20, 2011 | Epson Stylus Pro 7000 InkJet Printer
We have a Bissell Proheat 2X (model 8920). The problem we are having is when water/soap is initially released (all settings) it continues to leak out the front water spray nozzles unit the water...
Return it. It is faulty and should not do that. Mine does not. Does require changing water about evrery 10 minutes but one can see the filth in the water. Also re-clean with plain water over areas that were cleaned to remove all cleaner. Old cleaner in carpet to dirt is like a bug attracted to a bug zapper. It can be time consuming, but it will pay for itself and can do a great job if you pay attention when water or cleaner runs out, otherwise it will not clean properly!
Jan 30, 2011 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Less than one year old. Takes 10 or more minutes to brew a pot of coffee. I have followed cleaning and deliming instructions three times. Did not help.
Hello. the problem is the little sprayer that sprays water into the coffee grounds. They get clogged with coffee oil and coffee grounds. Unplug the machine, tip it upside down in the sink so the water doesn't go everywhere and use a straight pin to clean out the little holes of the spray nozzle. That nozzle should unscrew, which would make it easier to clean. When you are looking at the nozzle, unscrew it by turning it counterclockwise. Joe
Mar 03, 2010 | Bunn 10 Cup Home Coffee Brewer
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Button hole
I worked for two hours and kept getting terrible button holes.. the back side has loose thread while the front looks OK. I finally went back to my 30 year old Bernina to complete the button holes....
Does anyone know how to fix this problem?
Jun 27, 2009 | Singer CE-100 Futura Computerized Sewing...
Water fills machine but won't shutoff
ekrok, you are going to have to change the fill valve. If water is still filling when the unit is unplugged, that means the valve is stuck open. This is not a hard fix. You will have to remove the screws on the top in back. Should be three. If this is a GE you will have to remove the front header. Three screws in back of the front header. Now the top will slide off toward the back The valve is easy to get at. Get your part at a local appiance parts store or order it from repairclinic.com. Change it out and this will be a done deal, Catriver
Mar 07, 2009 | Whirlpool GHW9100L Front Load Washer
X5470
Cartridge left for long time ink gets dried thrn you get this message...try this
Cleaning procedure
Turn the cartridges up side down u will find the print nozzles
Remove the print cartridges.
Moisten a clean, lint-free cloth with water.
Gently hold the cloth against the nozzles for about three seconds, and then wipe .
Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe
With another clean section of the cloth, repeat steps 2 through 4 above.
Allow the nozzles and contacts to dry completely.
Reinsert the print cartridges.
Print the document again.
If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
Dec 24, 2007 | Lexmark X5470 All-In-One InkJet Printer
Kenmore elite top load about 3 years old
Check the boot for tears, also remove the lower axcess panel (Three torx screws or 7mm) and see where the water is coming from.
Sep 24, 2007 | Kenmore Elite 45986 Front Load Washer
Refrigerators Logo
287 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
