Question about Logitech Z-5500 Computer Speakers
The right speakers logitech Z 5500 do not work
The right speakers of my logitech Z 5500 does not put out sound. the right speakers work fine when hooked up to the left side so i know the speakers work. the wires work fine because when i switched the wire on the back of the sub the right side worked. all speakers work when using test and the fuse looks fine. it is hooked up to a toshiba 32" hdtv through an optical cable. ive had them for over a year now and they have worked fine up until about a month ago.
Try buying a new optical cable or change some settings on your tv.
Posted on Mar 02, 2010
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
Hi, i just recently bought some logitech z-5500 and have tried to hook them to my mac. The problem is that the speakers are far too quiet they all work but they are not giving out 505watts rms. My mac only...
Hey there,
The 3.5mm socket is the only thing you can plug into on a mac for speakers.
Have you checked to make sure that the system volume is turned up? Use the volume buttons on the mac keyboard to turn it up.
Let me know if this does or doesnt work and we'll try something else!
Good luck :)
Mar 08, 2011 | Logitech Z-5500 Computer Speakers
Hi have recently purchased logitech 5500 system, it was working fine for a few days but now even with no sound running through it when you turn it on blast out a loud sreeching short out sound, just...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 25, 2011 | Logitech Z-5500 Computer Speakers
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
No sound no light @ logitech z-5500
search for service center on net near you can not repair it your self or jast call them
Oct 24, 2009 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
My speakers work for a short while then cut out - please help
have you ever tried to instal a sound blaster sound card on your machine
Dec 12, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z-5500
Well you have some options, you can either live with 2 speakers and change the settings back to default. Im assuming the colors you have are orange black and green. black= the surround sound speakers. orange= center and subwoofer. green=right left front
Now if u want true surround sound then you need to buy a new card that had all the ports for your speakers.
Oct 21, 2008 | Logitech Z-5500 Computer Speakers
Centre Speaker No Sound
i can think of two things., you may need to do the update on your sound card and computer and make sure you have the correct codec's installed or also you may need to go to the web site of the makers of your logitech speakers and see if they have a common solution for this problem...... i also wonder if you should bypass the sound card and directly connect your speaker system to the out put port on your computer ..... give it a try what can it hurt .... if all else fails maybe there is a faulty wire in the speaker system ....... ahy ?
Jul 17, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
335 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
